need some more power?
Old Aug 27, 2006 | 07:29 PM
jasonM's Avatar
jasonM
Default need some more power?
just got z tuned and only made 330 whp
i just had motor rebuilt with wiseco and eagle rods 8.8 comp
so i raised boost (7lb pully to 9lb)on procharger
added rc 550 injectors, walboro 255, greddy ultimate
was expecting atleast 400 whp with new mods
should i be expecting more whp
Old Aug 27, 2006 | 07:37 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
you have test pipes/headers/exhaust?
jasonM's Avatar
jasonM
full dyno
Cannysage's Avatar
Cannysage
what are your mods? ya got TT?
Old Aug 27, 2006 | 07:39 PM
jasonM's Avatar
jasonM
just custom exhaust
had over 365whp 325 tq
with stock block and fuel with 7 lb
Old Aug 27, 2006 | 07:40 PM
jasonM's Avatar
jasonM
procharger
Old Aug 27, 2006 | 07:42 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
well you lowered your comp. ratio so that accounts for your lost HP. You did up your boost so something is still a little off. If you are still runng stock cats, thats the first thing I would change
Old Aug 27, 2006 | 07:48 PM
jasonM's Avatar
jasonM
could it be a bad tune
car hesitates when i get on it
Old Aug 28, 2006 | 08:57 AM
jpc350z's Avatar
jpc350z
The A/F looks very rich at aroud 5800rpm and takes a dump at 6000.. Smooth out this area and you should pick up Hp and maybe eleminate the hesitation.. Good luck
Old Aug 28, 2006 | 10:01 AM
Jonathan Allyn's Avatar
Jonathan Allyn
That lower comression really makes a difference. I would look at that A/F and push your boost up a bit further to make up for the loss of compression.
Old Aug 28, 2006 | 06:34 PM
jasonM's Avatar
jasonM
does anyone no if i should get a fuel return system or im i ok with just larger inj and intank fuel pump
Old Aug 29, 2006 | 09:28 AM
Quamen's Avatar
Quamen
A good rule of thumb is that all though it is not necessary (through the use of rising rate FPR's) a fuel return system is definitly a good idea for any form of forced induction.
Old Jun 10, 2007 | 01:05 PM
05nissan350z's Avatar
05nissan350z
i have 600hp on 10psi procharger get a better motor
Old Jun 10, 2007 | 01:19 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
yeah, ok sure you do. Maybe @ the crank. Or, you have an Ls1
loudtoyz
Apr 6, 2023 04:52 AM
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
codek
Sep 28, 2015 03:03 AM
