Clutch Noise?
Old Sep 2, 2006 | 08:28 PM
350Z_GTS's Avatar
350Z_GTS
Default Clutch Noise?
Ok, This is my first, brand new 06 Z. My question is i know it is new, but is there a reason when i take off in first gear, it seems to make a rattley sound from the clutch like it was bogging out. Is this normal or is this something that goes away after time? Another forum just says take it to the dealer, it under warranty, but i want to make sure i need to, cause apparantely the dealer said the clutch will make a noise in first gear when you drive it to like 10 mph, then let it idle down, then engage the clutch, it makes basically the same sound like when i take off. The dealer told me it was because the car has like no slips, it just grabs and goes, so i dont want to sound like an *** going back and asking about this noise. Someone please just tell me if i am crazy or is this normal. thanks
Old Sep 2, 2006 | 11:41 PM
Zreign's Avatar
Zreign
Perfectly normal. You will also hear it when depressing the clutch at low RPM. The sound is caused by the flywheel.
Old Sep 3, 2006 | 12:17 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Hi, I recommend you read the top 100 questions thread (link in my signature) before creating anymore new threads, and next time please use the search feature before posting as this topic has been discussed several times before.
Welcome to the forums
Old Sep 3, 2006 | 06:26 PM
EJOTAM's Avatar
EJOTAM
I just bought an 06 touring Roadster and it is doing the same thing. I was wondering if it was a problem and considered going to the dealer about it. Thanks for the post!
Old Sep 3, 2006 | 07:06 PM
350boyz's Avatar
350boyz
Hi.
I also have a problem. I'm not sure if this is the same problem as you are having.
My clutch is rattle when I press and hold it when idle. You can only hear it when you are inside your car by pressing and holding the clutch (close all windows and doors, no AC).
I knew that the rattle sound when you are in neutral is normal. But in my case, I have rattle when car in neutral and as soon as I depress the clutct the rattle from outside/under the car is stoped (which is normal), But then I close my door and I hear rattle slightly from my clutch inside the car. Seems like the rattle is just transferred (but not as loud as with the clutch out).
Is this normal, or my bearing/flywheel is going bad?
Old Sep 3, 2006 | 10:25 PM
silver nismo's Avatar
silver nismo
100% right i thought the same when i got my z
Old Sep 4, 2006 | 07:18 AM
Nismo350ZRT's Avatar
Nismo350ZRT
The cement mixer noise is normal. I had it in my 05 ZR and now my 06 coupe sounds the same.
Old Sep 6, 2006 | 01:44 PM
350Z_GTS's Avatar
350Z_GTS
Thanks for the help. It also makes a pop from the driver side inside the cabin, and it seems from the site it could be my clutch assembly. I didn't happen to see if this is bad, or just annoying. Cause the car did it for like a day then i just does it every so often, should i even bother lookign at having it fixed cause it will cause other damage, or just wait a while to see if it comes back?
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
