( at ) trans install
Old Sep 20, 2006 | 04:15 AM
jj350z's Avatar
jj350z
Default ( at ) trans install
How hard is it to change the AT trans in our cars? A couple of my buddies that are mechanics think they can do it in my garage on jack-stands. Then lift the tranny up with a floor- jack. Doable?
Old Sep 20, 2006 | 06:37 AM
USMC-Z's Avatar
USMC-Z
Z Veteran
I guess it is possible if you've got people knowing exactly what to do, but it will take double the time to drop it out than if you had a lift. Plus, no warranty at all if it doesn't work. I'd just take it to a shop.
Old Sep 20, 2006 | 03:45 PM
jj350z's Avatar
jj350z
I wouldnt have a warranty anyways. Its supercharged
Old Sep 20, 2006 | 04:12 PM
Eazzy's Avatar
Eazzy
Nuts and Bolts and common sense. MAIN thing: Be very careful when u slide ur converter on to the tranny making sure u dont mess up the front seal and making sure that the converter shaft locks into the pump drive. It should almost be rubbing the bellhousing. Then when its bolted up, slide the conv. forward to the flywheel, line up the bolts/studs and tighten them down in sequence with a drop of Loc-Tite
Old Sep 20, 2006 | 06:50 PM
jj350z's Avatar
jj350z
how long is the install for the tranny ( time wise )
Old Sep 20, 2006 | 07:09 PM
Eazzy's Avatar
Eazzy
If ur Hot--hour-hour and a half---If ur not ---week-- week and a half. J/K
Too many variables, Iv put in LOTS of trannys, Have yet to do an Auto on a Z, But Trannys are Trannys. Id say on the Z, couple guys that know a little and take the time to chk and double chk every thing------3-4 hours. I can install a 6 sp. and have it sitting on the ground in an hour and a half, working alone.
It shouldnt be an all night job but if it turns out to be ---so what. No sense in makin it a race.
Old Sep 21, 2006 | 06:53 AM
USMC-Z's Avatar
USMC-Z
Z Veteran
Too many variables, Iv put in LOTS of trannys, Have yet to do an Auto on a Z, But Trannys are Trannys. Id say on the Z, couple guys that know a little and take the time to chk and double chk every thing------3-4 hours. I can have a 6 sp. sitting on the ground in an hour and a half working alone.
Damn, thats come crazy timing. Wanna work on my car?
Old Sep 21, 2006 | 12:58 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Wouldn't it be better / safer to rent a tranny jack instead of precariously jacking the tranny with a floor jack?
Old Sep 21, 2006 | 02:03 PM
Minda's Avatar
Minda
jj350z, if you will be doing the 5AT swap can you take some pics in the process. That would be extremely helpfull for reference. Thanks!
Old Sep 21, 2006 | 02:07 PM
disturbed2483's Avatar
disturbed2483
it shouldn;t be to hard a buddy and me did my clutch and flywheel in my garage on jack stands and once every thing was put together it only took us about 2hrs to get the tranny back up and bolted on.
Old Sep 21, 2006 | 06:05 PM
jj350z's Avatar
jj350z
Nevermind I took it to Cottman transmission. Im payin $400 just to have it done right and safely.
Old Sep 21, 2006 | 06:08 PM
Eazzy's Avatar
Eazzy
All that typing for nothing. UGH. Watch them Fockers ---I HATE National companys.
Old Sep 22, 2006 | 10:03 PM
jj350z's Avatar
jj350z
Got the car back today, they did a great job i must say. Whats the breakin period for a brand new trans?
