RevUp Oil Consumption TSB and discussion
Old Dec 10, 2007 | 09:46 PM
  #2181
ZeeForce's Avatar
ZeeForce
Default Post up your V2 Install Stats
The quantity of data is pretty weak. Guys please update, it's for the first page. For all with newly installed V2's, please post up your stats.
Please use the template on the first page and post up your stats.
Thanks
-Curtis
Old Dec 10, 2007 | 10:38 PM
  #2182
9kFever's Avatar
9kFever
Mine was 1.2 qts low after 700 miles. So updated it to 25mm? V2
Old Dec 11, 2007 | 07:23 AM
  #2183
06CPV35's Avatar
06CPV35
Lets see...1qt=24mm. 0.2qt=1/5th qt= ~5mm (0.25qts=6mm)
24mm+5mm=29mm is my guess.
Originally Posted by ZeeForce
Attachment 170665
Thanks
-Curtis
Maybe a friendly PM to those members to update would work
Old Dec 11, 2007 | 05:33 PM
  #2184
ZeeForce's Avatar
ZeeForce
So is this correct?
Did you go from 15 mm to 29 mm in 100 miles?
Template:
Status: Still Consuming
OC: 29 mm
Engine Install Date:
Engine part number:
Mileage on Engine: 700
Miles since last engine service: 700
Oil Type/Brand/Weight: ?????
Old Dec 11, 2007 | 05:34 PM
  #2185
ZeeForce's Avatar
ZeeForce
Good idea!
Old Dec 12, 2007 | 06:08 AM
  #2186
RobD's Avatar
RobD
Default G35
Been lurking here after I ran low enough on oil that the engine
was making a terrible noise. Found this thread and took
the G35 in for the oil consumption test. It showed
I was burning quite a bit. In each of the three 1000 miles tests
I burned .5, 1.0, and 1.5 quarts. I do about 30,000
miles a year so I basically need to add a quart every 10
days or so now. Infiniti just called and said to bring the
car in for a new engine. I guess I'll ask to see the
part number. But I should thank all
the others that had a much more difficult time
getting this problem fixed for making it easier
for the rest of us. Thanks. I'll let you know how it goes.
Rob
Old Dec 12, 2007 | 06:28 AM
  #2187
BabyZiLLa's Avatar
BabyZiLLa
Well my engine install date is set. January 14th. Personally i wanted it in the summer, but they wouldn't budge. Now i have to take it out of storage in the middle of winter. Get the engine installed, then put it straight back in without being able to test drive.
Old Dec 13, 2007 | 06:44 PM
  #2188
sqashybus's Avatar
sqashybus
I bought my 2006.5 base 350z from a Nissan Dealership used. Does the TSB still apply to my vehicle since i bought it used from a Nissan Dealership? It has 30k miles
Old Dec 13, 2007 | 07:51 PM
  #2189
9kFever's Avatar
9kFever
it sure does. 5 yr/60,000 warranty
Old Dec 13, 2007 | 08:39 PM
  #2190
sqashybus's Avatar
sqashybus
Oh ok thx!
I checked it earlier and its up to about 2/3 of the hash mark. I'm 1100 miles into my change. Looks like i have to pay my Nissan dealership a visit
Old Dec 13, 2007 | 10:15 PM
  #2191
Z12350Z's Avatar
Z12350Z
So if you passed the warranty and your burning oil on an 03. Nissan wont do anything about it?
Old Dec 14, 2007 | 02:24 AM
  #2192
Celestak's Avatar
Celestak
Well, add me to the list going in next week for the OC test, which i thought I was on already but because one of tech's apparently didn't know his job I'll be starting over again next Thurs. To my ignorance, you must use 5w-30 oil when running the OC test per Nissan instructions but It's cool because the shop foreman told me that it would be free of charge so that fine with me just as long as they man up when it's still showing consumption.......
Oh and "Z12350Z" I'm not an expert by any means but If you're not under warranty any longer there's nothing nissan will do for you, free of charge that is....
Old Dec 14, 2007 | 06:37 AM
  #2193
cheshirecat79's Avatar
cheshirecat79
No, and it's also much more rare for an '03 to burn oil. I would put my money on an oil leak rather than you actually burning the oil inside the engine.
Old Dec 14, 2007 | 10:18 AM
  #2194
Z12350Z's Avatar
Z12350Z
No i get blow by. I get the home made oil catch can to fill in about two weeks. So i figure get an oil cooler and run thicker oil. Right now German castrol. next depending on oil analysis something with a 40 weight and i doubt ill be burning as much.
Old Dec 14, 2007 | 05:57 PM
  #2195
ZeeForce's Avatar
ZeeForce
Rob
Amazing what a TSB will do...
Congrats and keep us posted.
Old Dec 14, 2007 | 06:34 PM
  #2196
06CPV35's Avatar
06CPV35
TSB did nothing for him. He has a G not a Z.
His 2nd and 3rd consumption test results qualified him for replacement under Infiniti's still current 1qt/1000mi or worse replacement standard.
A NorCal member on Driver just picked up his G with VQ replacement. The part number still reflects the V2. So...still no V3 released yet, if ever.
Old Dec 14, 2007 | 06:42 PM
  #2197
ZeeForce's Avatar
ZeeForce
Ooops, sorry I missed the G in his post. Thanks for the correction.
Good for him, hopefully he will not need a another replacement. Sounds like Infinity is getting in an ample supply of replacement engines.
Hopefully the TSB for the G family will not be too much longer.
Old Dec 16, 2007 | 12:16 PM
  #2198
Blwn_By_Twins's Avatar
Blwn_By_Twins
I own a 06 base model with a m/t. I've only put about 1200 miles on it since I bought it used with 10k on it. I'm trying to keep up with this in case I have the problem. How common is it? Do most of the 06 m/t have the problem? And with so much oil being burnt, is anyone noticing smoke from the exhaust? I'd think it would be pretty noticeable burning 1+ quarts per 1k miles.
Old Dec 17, 2007 | 05:22 AM
  #2199
RobD's Avatar
RobD
Default G35
Getting a new engine at Infiniti for my G35 seemed only
slightly more difficult than an oil change. It took them a
day and a half. I confirmed the V2 part number on my
service receipt. So now we'll see how it goes.
BTW, are you guys following any break in procedures with
the new engines? They told me nothing about it. Also, what
about the warranty for the engine?
Rob
Old Dec 17, 2007 | 09:58 AM
  #2200
sqashybus's Avatar
sqashybus
Hey i have smoke coming out of my exhaust, pretty sure it's burning oil.
