RevUp Oil Consumption TSB and discussion
Old Feb 19, 2007 | 03:29 PM
  #321
jacII's Avatar
jacII
Hey Guys - new to this forum. I didn't scroll through all the posts on this thread but there is a similar thread on www.g35driver.com. Look for the thread entitled "Everyone: Check Your Oil ". I have an 06 6MT sedan that just had the engine replaced at 8400 miles. Same story as most of you guys, burning 2+ quarts every 3000 miles. Picked up the car this past Saturday. I'll keep my fingers crossed on this one.
Joe
Old Feb 19, 2007 | 04:34 PM
  #322
dbasal's Avatar
dbasal
Joe
That answers the question some asked earlier. Seems like Nissan has a pandemic on their hands.
Old Feb 21, 2007 | 12:26 PM
  #323
bofa's Avatar
bofa
I sent my paperwork in today. In Florida, I'm told it can be a 40 day process, so here goes...
Old Feb 21, 2007 | 09:16 PM
  #324
dbasal's Avatar
dbasal
Best of luck to you. I just had my oil changed back to conventional to see what that does to it. If I have the same problems or worse, I will be going the same route. It would be nice if the consumption stops with conventional, but I am not hopeful.
Old Feb 21, 2007 | 10:19 PM
  #325
creationv2's Avatar
creationv2
gl bofa! as for me lets see how well i do when i get my oil changed this weekend...:-\
Old Feb 21, 2007 | 10:56 PM
  #326
aren21's Avatar
aren21
Its been 4,000 miles, and Im down 3/4 of a quart. Im not going to have any time at all to take it to the dealer, so I just added oil. I figured: 1: they will say its normal consumption, 2: there is no fix yet from what it seems, so I am not really looking forward to get another defected engine. Im just going to wait untill they have a fix, then make an attempt to get a replacement.
Old Feb 22, 2007 | 07:49 AM
  #327
Bevo's Avatar
Bevo
Same here, my engine consumes about 1 qt per 4,000 miles. Comparing to other owners, i think it is acceptable for now.
Old Feb 22, 2007 | 03:34 PM
  #328
bofa's Avatar
bofa
I've been running conventional this whole time so I don't have a lot of hope.
Old Feb 23, 2007 | 05:03 AM
  #329
350Z_LMS's Avatar
350Z_LMS
nissan here in italy are going for a piston ring change on mine, not an engine replacement. this sucks
Old Feb 23, 2007 | 08:47 AM
  #330
dbasal's Avatar
dbasal
OH! For some reason I thought you were putting Mobil 1 Syn in your car. Thanks for letting me know even though I am not as hopeful now.
Old Feb 23, 2007 | 09:05 AM
  #331
Theatrix's Avatar
Theatrix
Professional
I have run synthetic since my first oil change. The dealer put in conventional and I still burned 2 1/2 qts in 700 miles. I did burn more while running synthetic. But it was also summer and I ran harder.
Its been 4 days since my reading and I am still waiting for the dealer to call me. I placed a call after two days which was not returned as of yet.
Old Feb 23, 2007 | 04:15 PM
  #332
Consar's Avatar
Consar
Nissan Australia are telling us that it's not a problem, oil loss and pinging is "within acceptable tolerances". Can you believe these guys???
They say it's a one off, not a pandemic problem. Blaming me initially for not running in the car properly and then saying I don't drive it hard enough? What the? After changing the motor, they ran it in, guess what? Same again!
They disregard these forums saying that anyone can say anything on a forum. Well, Nissan Australia, stop reading this and fix the problem!
Old Feb 23, 2007 | 05:38 PM
  #333
bofa's Avatar
bofa
^What a bunch of douchebags... they can at least own up to the problem...
Old Feb 23, 2007 | 08:46 PM
  #334
dbasal's Avatar
dbasal
Well. It appears that Nissan Australia is about as stupid as Nissan North America. Well, I would make sure you have a lot of documentation, then go after them when the motor prematurely bites the dust.
So exactly how does one decide pinging is normal anyways? That is the craziest thing I have ever heard. Even with the problem not being fixed with a new engine, that pinging normally says the engine is pretty much shot.
This whole thing is turning into Tire Feathering Part II. Nissan has yet to learn anything through all of the problems they have had.
This whole thing has just raised my blood pressure again about 50 points. Everytime I read about Nissan not taking this issue head on it just pisses me off!
Best of luck to you with these brainiacs.
Old Feb 24, 2007 | 11:11 AM
  #335
TheProfessional's Avatar
TheProfessional
Default 2006 model oil analysis 2nd round
I had minimal to no burnoff after 7,350mi between my last oil change using RP 10W-30 and a K&N oil filter. I did add 1 quart at 5,000mi per the burnoff I noted during the oil change prior. Which this may have been blow-by rather than burn off given the mileage.
I added the update to another thread dealing directly with oil change intervals, the POSITIVE analysis can be found here:
https://my350z.com/forum/showpost.ph...6&postcount=32
Old Feb 24, 2007 | 01:45 PM
  #336
jim_ja2005's Avatar
jim_ja2005
Hi guys!
My name is Jim and I'm from Sydney Australia. I have a 2006 350z track model and have been burning a ****load of oil. 3.5 litres in the first 2000km's, another 2 litres in the next 1000km and another 2 litres in the following 1000kms.
Nissan Australia has up to now done very little and has pretty much denied there be a major problem!!!!!!!!!!!!!
I had no choice so have taken them to court! Have had one hearing 2 days ago where Nissan finally admitted that there is a problem with my car and have offered to replace my engine.
I declined and told judge that replacing engine is not a solution as the engine is a dud and a common problem with this revved up engine in 2006 models. I have asked for a refund on the car and nissan can take my car back.
Judge said that if I can prove that this is a comon problem, he will order Nissan to give me a full refund!
I know that many of you from around the world are experiencing the same or similar problems.
This is where i need your help. Could those of you that have experienced the oil problem please type up a brief history and outline of your experiences and Nissan response/solution. You are going to have to state your name and address in this letter as judge needs to know that cases are real and not some bull**** I am making up. I know its asking alot but if I win this and Nissan is forced to refund me the money, then it sets a precedence and anybody else in a similar position as me can do the same.
You can email them to me or send them to me on this forum.
Appreciate your help and i will let you guys no how it all goes.
Thanks
Jim
jimaskounis@yahoo.com.au
Old Feb 24, 2007 | 06:12 PM
  #337
bofa's Avatar
bofa
^I'll do you one better and email you a copy of the letter I sent to the Better Business Bureau and Nissan North America as part of my Lemon Law paperwork. I won't have it until Monday though because it's saved on my work computer. It documents everything.
Old Feb 24, 2007 | 06:26 PM
  #338
aren21's Avatar
aren21
Hey Jim, check your PM.
Old Feb 24, 2007 | 08:11 PM
  #339
JoeyFyed's Avatar
JoeyFyed
yea... been through what seems to be around 3-3.5 quarts in 1600miles...
Old Feb 25, 2007 | 01:38 AM
  #340
jim_ja2005's Avatar
jim_ja2005
Hi bofa
Thanks heaps mate, I appreciate that, will be great to submit in court.
Will let you know how it all goes and good luck with your car!
JIm
