RevUp Oil Consumption TSB and discussion
Old Oct 25, 2008 | 08:25 AM
  #3561
06CPV35's Avatar
06CPV35
Originally Posted by Nismospeed4life
Thanks 06CPV35! I was wondering though, if I were to install a paper one, once it becomes dirty would I have to buy another one? Or do I just clean it like the oil base ones and put it back on?
Amsoil are cleanable, but not like you would an oiled one. No on replacing every time. Still looking for those dimensions...lol
-edit-
Here check this out
http://www.amsoil.com/storefront/eaau.aspx
Specs & photos are also as a .pdf in that link.
Hope that helps.
Old Oct 25, 2008 | 08:43 AM
  #3562
Nismospeed4life's Avatar
Nismospeed4life
No rush on the dimensions, however, I do apreciate you looking out for a brother.
In other notes, I was told that my car should be ready by Monday. I took it in on Thusrday evening. I am just hoping that they dont mess up my bab while she is there. I want every nut & bolt back on her, LMAO!
Old Oct 25, 2008 | 08:46 AM
  #3563
Nismospeed4life
Thanks for the link 06CPV35 You guys are the best!
Old Oct 25, 2008 | 09:05 AM
  #3564
06CPV35's Avatar
06CPV35
Definitely not the kind of weight reduction you want lol.
No worries bro. Have a great week-end and hope all is good Monday when you get her back.
Old Oct 25, 2008 | 09:12 AM
  #3565
Nismo1182's Avatar
Nismo1182
Originally Posted by ZeeForce
I believe it is the 18mo/18k miles, but may want to double check from the link on the first page of this thread.
I did.
Here in FL we have 2 years. But a few CA members just had their cars bought back after their 18mo.
Just hoping I still have a chance too.
Old Oct 25, 2008 | 09:19 AM
  #3566
Nismospeed4life
^^ Good luck!
Old Oct 25, 2008 | 11:15 AM
  #3567
ZeeForce's Avatar
ZeeForce
Originally Posted by Nismo1182
I did.
Good to hear about CA buy backs after the 18/mo/18kmi. It's been awhile since I read up on LL in CA, so I'm a lil rusty. Off the cuff though I believe it stated as long as the OC is recorded on a service invoice as reported loosing oil by the customer within that time frame/miles. Don't quote me on that though.
Hope you still have a chance...gl
Old Oct 25, 2008 | 11:17 AM
  #3568
ZeeForce's Avatar
ZeeForce
Thanks 06CPV35, I was outside washing/waxing for a EuroSunday car show tomorrow. Well back outside now, give ya a call.
Old Oct 25, 2008 | 01:47 PM
  #3569
antennahead's Avatar
antennahead
In last pix, the PCV is on the left taped up and sticking out from valve cover. Yup, that's the new one. Should have new plugs installed and have the revised valve guide seals as well.
Thanx ZeeForce for that comment earlier. I subscribe to about....4 other OC threads plus this one. Just sharing the knowledge and continue to do so when I can from our brainstorming/ideas/personal experiences and UOA results.
My new frustration has been my worsening detonation and has been my new 100% focus now. Anyone have a Consult II or Cipher they can loan me? lol
You know who to hit up on your Amsoil products
"In last pix, the PCV is on the left taped up and sticking out from valve cover. Yup, that's the new one. Should have new plugs installed and have the revised valve guide seals as well."
Can you tell me when they changed/started shipping V2s with this revision? Was it from the start? According to my mechanic, valve guide seals is a major cause of the OC. I had my V2 installed last August (2007). Is that engine before the new PCV and valve guide seals? Thanks guys!
John
Old Oct 25, 2008 | 02:36 PM
  #3570
Nismospeed4life
Sorry guys, I was moving my pictures around in my hosting website and I screw the pictures that I had previously posted. I will fix it in a few minutes!
Old Oct 25, 2008 | 03:28 PM
  #3571
06CPV35's Avatar
06CPV35
John
Unfortunately I have no idea when that revision was done. My master mechanic wouldn't say. Did say mine had it tho as of May 08 with my swap.
Old Oct 25, 2008 | 03:30 PM
  #3572
Nismospeed4life
Ok, pictures are fix.
Old Oct 25, 2008 | 03:46 PM
  #3573
06CPV35's Avatar
06CPV35
Quicky update with another 2K on my V2 since 3750 mi oil change to current 5700 = 8mm down again. No further OC improvement it seems, but my last 350mi was solid spirited driving. IDK...will monitor next 1800 with normal driving habits and see how much more OC at end of this oil service interval. Hope not another ~8mm more. *crossing fingers*
Old Oct 25, 2008 | 03:52 PM
  #3574
antennahead
Thanks, I fear my early V2 does not have this enhancement
John
Old Oct 26, 2008 | 05:23 AM
  #3575
mcbrown35's Avatar
mcbrown35
5/5/08 10102-AC7MZ V2 37,815
10/22/08 Took possesion 38,328 Oil full
10/25/08 38,523 full on cold
10/26/08 38,730 full on cold
Have been sticking to 4000RPM break in. Fingers crossed.. So far so good...
Old Oct 26, 2008 | 03:39 PM
  #3576
Chaser720's Avatar
Chaser720
Lemoned Z
just changed my oil today at 5K
Added a quart at 3000K and 3 1/2 quarts out.
The engine ATE 2 1/2 quarts...
EDIT: Im still on the original engine with 35K miles. Going in for work next week some time.
Old Oct 28, 2008 | 01:44 PM
  #3577
Nismo1182's Avatar
Nismo1182
Who else have had their Z bought back?
Old Oct 28, 2008 | 02:47 PM
  #3578
Nismospeed4life
ZeeForce,
Will they give me a whole new warranty on the new engine?
Old Oct 28, 2008 | 08:25 PM
  #3579
ZeeForce's Avatar
ZeeForce
John
No one knew, not NNA, not Dealers, not the NNA regional reps, It was and still is, all kept secret on what was and still is being replaced in the freshly built engines.
It all goes back to the same original speculation from May of 2007, which were the rings, possibly pistons, valve guides, PCV valve etc...etc..
I would speculate (guess) that the valve guides and seals were replaced from the first engine back in May of 2007.
Old Oct 28, 2008 | 08:36 PM
  #3580
ZeeForce's Avatar
ZeeForce
ZeeForce,
Your original warranty still applies, no new warranty on the engine. So you still get the 60mo/60k mile warranty as on your original engine/car.
Extended Warranty???
Very few have received the extended warranty. I was soooo lucky and kept calling back NNA after I received the fresh engine. And after two NNA reps, the third one (a gal out of Canada) went to bat for me with the supervisor and it went to the board. They called my dealer's service mgr and asked his opinion, and then it went to the board.
I got one, and have only heard of one other person getting one.
100k mile warranty or by the year 2011, which ever comes first.
Cheers
Curtis
