RevUp Oil Consumption TSB and discussion
Old Feb 15, 2012 | 05:01 PM
  #4601
cmcurran5's Avatar
cmcurran5
alright so quick update, nissan told me to go screw. i fought for a few weeks with nissan of america and they had the same answer. now im pretty much on my own. my question is, what exactly needs to be replaced. should i get a rebuild kit and do pistons, rings, etc. or is is just bearings and rings.. i have a very capable friend with a shop waiting for the go ahead..
Old Feb 15, 2012 | 05:33 PM
  #4602
Wu-Watt's Avatar
Wu-Watt
It needs to be rebuilt and will cost like $5000. At least.
Old Feb 15, 2012 | 05:46 PM
  #4603
e30cabrio's Avatar
e30cabrio
Having gone through exactly this and spent 14k I'll ask how does it run and how much oil is it using? If less than 2 quarts per 1k I'd say just put in the oil.
Old Feb 15, 2012 | 05:56 PM
  #4604
Wu-Watt's Avatar
Wu-Watt
Ya but you have a baller engine!! What whp is it making? How does it sound??
Old Feb 15, 2012 | 08:29 PM
  #4605
cmcurran5's Avatar
cmcurran5
im losing just under a qt every 1k, but the problem is i want to go FI.
Old Feb 16, 2012 | 02:53 AM
  #4606
e30cabrio's Avatar
e30cabrio
312/321 closed. 331/347 cutout open.
I you are going FI you needed to build it either after you did it and it died or as a pm.
Old Feb 16, 2012 | 04:57 AM
  #4607
cmcurran5's Avatar
cmcurran5
i was talking with sasha and he has a kit with low boost that would work on stock internals. im not looking for a 10 second car. just something more so im not getting beat by the sti's and honda 2000's
Old Feb 16, 2012 | 05:33 AM
  #4608
e30cabrio's Avatar
e30cabrio
Then I'd risk it and build if/when necessary. I like my build but honestly if I had it to do over I'd just be filling the oil.
Old Mar 1, 2012 | 07:31 PM
  #4609
BOATS N HOES's Avatar
BOATS N HOES
would resolved TSB's be noted on a CARFAX?
Old Mar 25, 2012 | 02:21 PM
  #4610
end of z world's Avatar
end of z world
When did they start doing the v2 replacement? And where is the v2 is badge? I have an 06 track and the swap was done jan 07.
Old Mar 26, 2012 | 07:12 AM
  #4611
06CPV35's Avatar
06CPV35
My best guess when V2's (version 2) started was when Nissan released the original TSB for long-blocks back in Nov 07, Jan 08 for Infiniti. Although, rumor has it that maybe V2 production started back in mid 07, looking at the original Infiniti TSB which excluded mid 07 and newer built G35's with revup VQ's.
There is no V2 badge on the VQ's. V2 was dubbed on the forums only meaning a second version (so-called fix) from Nissan/Infiniti.
Old Mar 26, 2012 | 12:35 PM
  #4612
thekinn's Avatar
thekinn
there is a part number for the engine in the tsb - it does not include 'v2' - i think v2 was just the consumer abbreviation for it
Old Mar 26, 2012 | 08:52 PM
  #4613
end of z world
[QUOTE=06CPV35;9668942]My best guess when V2's (version 2) started was when Nissan released the original TSB for long-blocks back in Nov 07, Jan 08 for Infiniti. Although, rumor has it that maybe V2 production started back in mid 07, looking at the original Infiniti TSB which excluded mid 07 and newer built G35's with revup VQ's.
There is no V2 badge on the VQ's. V2 was dubbed on the forums only meaning a second version (so-called fix) from Nissan/Infiniti.[/QUOTE
Hmmm well at least I got long block replacment..ill try and locate that part number. Any ideas where its stamped?
Old Mar 27, 2012 | 09:58 AM
  #4614
06CPV35's Avatar
06CPV35
^You may have gotten one of the first batches of V2's (rumor has it) from Japan.
No part number stamped on engine, only serial. Mine is located here (red arrow):
Old Mar 27, 2012 | 12:01 PM
  #4615
BOATS N HOES
Old Mar 27, 2012 | 03:49 PM
  #4616
thekinn's Avatar
thekinn
I doubt it. It is service performed on the car.. major service.. but still. Not an accident or change of owner.
Old Mar 27, 2012 | 10:26 PM
  #4617
end of z world
THANK you so much kind sir. And I betchya its one of the first of the v2s I usually get lucky lol.
Old Apr 16, 2012 | 12:55 PM
  #4618
B_Dangerous's Avatar
B_Dangerous
I bought an 06 6mt track in march,I am the third owner. It has 58k and after discovering this thread I immediately changed my oil (even thought it was just done) and had 2qts and some change in the motor after 2k!!!Went to the stealership and found that my powertrain warranty expired on 12/31/11. Started the oc test process.
What are some things I can do to get a leg up in this situation and what is the likelihood of getting an eng swap at this point?
I'm sure some of these questions are answered in the thread but this thing is like an effing novel and bounces from subject to subject.
Thanks.
Old Apr 16, 2012 | 01:11 PM
  #4619
cmcurran5's Avatar
cmcurran5
Thanks.
if you just bought it then you should be able to return it with the lemon law no?
Old Apr 16, 2012 | 02:21 PM
  #4620
B_Dangerous
I bought the z from an owner in vancouver So now I'm even more apprehensive as to if it's even worth my time as it's past powertrain warranty and wasn't bought through a dealer. I think I might just be sol and checking my oil every time I drive. I wish I had done more research..I love this damn car though!
