I searched so flame away, Governor issues.
Old Dec 4, 2006 | 11:13 PM
_Donovan_'s Avatar
_Donovan_
Default I searched so flame away, Governor issues.
I just want to know if there is a way to remove the governor myself or if there is something I can buy to do it. OK, thanks, Later.
Old Dec 4, 2006 | 11:32 PM
Mike Wazowski's Avatar
Mike Wazowski
technosquare reflash
http://www.technosquareinc.com/nissanflash.htm
Old Dec 5, 2006 | 12:26 AM
undrgnd's Avatar
undrgnd
It's officially and commonly called a speed limiter or a fuel cutoff. Search that.
Old Dec 5, 2006 | 05:41 AM
first350's Avatar
first350
http://alteredatmosphere.com also can do a reflash that removes the speed limiter.
-Peter
Old Dec 5, 2006 | 11:02 AM
_Donovan_'s Avatar
_Donovan_
Thanks, I really didn't even think of that.
Old Dec 7, 2006 | 07:42 AM
KPierson's Avatar
KPierson
Both the rev limiter and the speed limiter are computer controlled, so you can't just 'remove' them. A reflash or piggyback is needed. My UTEC has raised my rev limiter and eliminated my speed limiter.
Old Dec 7, 2006 | 08:28 AM
Ghost 350z's Avatar
Ghost 350z
Are you constantly wanting to do ove 150 mph?
Old Dec 7, 2006 | 09:01 AM
THE TECH's Avatar
THE TECH
I thought the Governor had to be voted out or impeached??
Old Dec 7, 2006 | 01:27 PM
_Donovan_'s Avatar
_Donovan_
I travel a lot, and on some trips those open roads though Texas, New Mexico, or Arizona would be a lot of fun to see what it can really do.
Old Dec 7, 2006 | 02:31 PM
Zquicksilver's Avatar
Zquicksilver
I'm not suggesting you don't have fun, just be careful at that speed on open public roads. Open being the key word here... blown sand across the road, critters deciding to scurry across at the last second, gust of wind, blow a tire on an object you didn't forsee being there, or just blow a tire period and slide off the road then flip a few times once you catch soft ground, unprotected by track/gard rails. Anyway, just a few thoughts, especially since you seem to want to do this often.
I believe this is the link to the JUN 350z when it blows a back tire at 200, its brutal...
http://www.svspower.com/images/upload/video_4_0.avi
Zquicksilver
Old Dec 7, 2006 | 09:41 PM
_Donovan_'s Avatar
_Donovan_
Thanks for the concern. I know I have a problem with speed. These things come across my mind at times. At least the Z is fairly safe in comparison to a civic or whatever. Some room for error. Once again, thanks for the concern though.
Old Dec 7, 2006 | 10:50 PM
Abishop's Avatar
Abishop
Hey man, nobody is going to flame you for not searching, just chill out....
Old Dec 7, 2006 | 11:20 PM
_Donovan_'s Avatar
_Donovan_
LOL, I think every post I ever have done with a question about anything someone has told me to search. And in a really irritating way.
Old Dec 8, 2006 | 03:00 AM
gringott's Avatar
gringott
That can't be. Not on this forum. I'm sure you are just paranoid.
To the OP: UTEC somehow "avoids" the speed limiter, I would guess because it provides the fuel etc, so the ECU is most likely saying "cut fuel" and the UTEC could care less. I do know that since installing the UTEC the tire pressure sensor warning does not appear anymore when I have not registered the TPS on the current set of wheels. That is what I find odd.
Old Dec 8, 2006 | 03:08 AM
KPierson's Avatar
KPierson
My tire pressure sensors work fine. They damn TPS light has came on at least three times since I've installed my UTEC.
Old Dec 8, 2006 | 03:22 AM
gringott's Avatar
gringott
Mine always worked right. But I have two sets of wheels and tires, and when I would switch them of course I would get the warning after driving a bit, until I took them to my buddies shop and had them registered. After the UTEC, the warning never appears. You have the opposite issue. WTF?
Old Dec 8, 2006 | 03:54 AM
KPierson's Avatar
KPierson
Well, with the cold weather my tire pressure has been low! I would make sure they were registered correctly.
Old Dec 9, 2006 | 09:54 AM
stan's Avatar
stan
does anyone know how much the technosquare reflash is? i just scoured their website and can't find a price on there.
Old Dec 9, 2006 | 04:24 PM
gringott's Avatar
gringott
Last time I looked it was gone also. But if I remember right, it was around $500 or a little less.
Old Dec 10, 2006 | 01:09 AM
undrgnd's Avatar
undrgnd
Does anyone else here think it's a total waste of $500 JUST to remove a safety feature which will not hinder spirited driving 99.999% of the time? I could understand it if it was done as part of a reflash aimed at improving performance. Hey, it's your money, spend it as you wish.
