First mod list
Old Dec 22, 2006 | 10:26 AM
ZSpectrum's Avatar
ZSpectrum
Default First mod list
How does this sound for my first run of n/a mods
skunk plenium spacer
jwt pop charger
hks ti dual exhaust
straight pipes
technosquare reflash or utec or similar engine management
seem pretty solid to everyone
Old Dec 22, 2006 | 10:28 AM
G1s Z's Avatar
G1s Z
Not bad at all. Have you thought about installing an aftermarket underdrive pulley. One of the cheaper mods, and helps out a decent amout.
Old Dec 22, 2006 | 10:32 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
slow down, how much is that going to run you?
250 for spacer, 110 for pop charger, 1600 for exhaust, 200 for good tp and 500-1500 for reflash/utec and tuning. Whos doin the install?
sound about right? 2660-3660. you could save a bit longer and go fi or, get nitrous and a few breather mods and have tons more power.
good mod list, mine is similar but i built it over time and not knowing na is a hard way to get hp. With my mods im sitting at 240whp on a dd dyno.
Old Dec 22, 2006 | 10:36 AM
streetracer's Avatar
streetracer
I think it removes the OEM bar. Verify.
jwt pop charger
Nice sound. Thats about it.
hks ti dual exhaust
Very high price for little hp, but good pipes.
straight pipes
I agree.
If you re-flash, get the pullleys.
If you have the rev-up, get the MREV2 lower plenum mod. If you have the 287, don't.
Old Dec 22, 2006 | 10:39 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
sounds like you've done your research!!! That makes us happy. Just my 2 cents here though. I go UTEC vs a flash. Unless it a custom flash for YOUR car/ engine I don't like them. Flashes are a guess of what your car should be doing with your mods. A UTEC you can do a lot more and tune for your engine. Just do a bit more research on EMS & flashes.
Old Dec 22, 2006 | 10:40 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Plus with a UTEC, you can change it later if you do something different, like go F/I or other major changes.
Old Dec 22, 2006 | 10:41 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Good call Dave!
Old Dec 22, 2006 | 10:44 AM
Mark Basford's Avatar
Mark Basford
Ive just fitted lightened pulleys, Skunk Plenum spacer, grounding kit and a K&N Panel filter.
Not sure of the numbers but there is a marked improvement.
Also bought a 'cheap' exhaust.........never again.........doesn't fit!
Any ideas on a good after market system?
Old Dec 22, 2006 | 10:50 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I'm running just APS test pipes and love it. However I'm looking at the Tanabe Touring w/ Tanabe y-pipe. I've also seen the TurboXS complete cat-back for sale around $750 new!!! Do a search for it or search the marketplace. Used exhaust are always selling.
Old Dec 22, 2006 | 11:09 AM
ZSpectrum's Avatar
ZSpectrum
i will be installing all of the mods+ the utec. I don't know who will be tuning yet, i havn't found out somewhere good to take it locally. I was looking into spray, as someone suggested but it seems to risky right now. I would love to go fi, but i do have other hobbys. The hks i agree is alot of money for very little, but i love the sound. The testpipes seem like a good idea, easy hp for very little. The only problem is inspection, but i'm sure i can find someone local The underdrive pulley sounds like a good idea as well. I was also looking into a lighter weight flywheel, only problem with that is the sound. I also couldn't find if raising the idle was a deffinite solution for it. Also i have to keep in mind that along with the performance upgrades, I am also doing a completely new stereo for the z. Screen front speakers, and subs.
Old Dec 22, 2006 | 11:35 AM
ZSpectrum's Avatar
ZSpectrum
right now i have on the way the pop charger and a new shift **** plus the subs and amp.
Old Dec 22, 2006 | 02:09 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
You can also go with hi flow cats, which will get almost as much gain, but still pass inspection, and preserve the environment...
Old Dec 22, 2006 | 02:13 PM
ZSpectrum's Avatar
ZSpectrum
why would i want to do that
but seriously i might go that route.
Old Dec 24, 2006 | 02:38 AM
Mark Basford
jwt pop charger
hks ti dual exhaust
straight pipes
Beware the plenum spacer! Your strut brace may not fit after....
I just fitted a 5/8th spacer from Skunk, works very well but no more bracer bar!
But do you really need it?
Old Dec 24, 2006 | 09:45 PM
ZSpectrum's Avatar
ZSpectrum
im not sure on if i need it, i plan on going to an aftermarket one though. Like the greddy
Old Dec 25, 2006 | 04:00 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
The Motordyne 5/16th Spacer will work with factory strut brace.
