I need some advice on my idle
Old Jan 12, 2007 | 11:28 AM
DustinZ33's Avatar
DustinZ33
Default I need some advice on my idle
I've searched but haven't come up with a precise answer on what is too low of an RPM. PROBLEM: I just had my oil change done at Nissan and ever since then my idle has been lower. Before the oil change, it was usually around 900-1000 and now its like this (see pic below). I was just wondering if there is something wrong and if I should bring it back to Nissan. I first happened about 3 nights ago. When it first happened, my car almost shut off because it dropped so low. Now its just stays this way after warming up. The car does seem kinda shaky at this RPM like it is going to shut off but it hasn't quite gotten there yet. What do you guys think?
Old Jan 12, 2007 | 12:23 PM
first350's Avatar
first350
mine idles around there...it's felt 'shaky' since I first bought it.
Old Jan 12, 2007 | 12:26 PM
AroundMyHorn's Avatar
AroundMyHorn
mine does the same thing. Besides the ugly noises it can make at times no problems yet
Old Jan 12, 2007 | 12:41 PM
z2envy's Avatar
z2envy
mine does the same thing too. At first I thought something was wrong but I guess it's just the way the car is?
Old Jan 12, 2007 | 01:00 PM
Machupo's Avatar
Machupo
mine always idled at 650 with the stock engine, but we had to raise it to 1000 to prevent stalling after the tomeis
Old Jan 12, 2007 | 04:53 PM
Cannysage's Avatar
Cannysage
I've changed to synthetic and smoothed out my idle a bit. there was a slight bumpiness of the needle and now it's steady. not sure about your issue, though.. that occurs when you have an exhaust leak or a misfire, but that'll throw a cel..
Old Jan 12, 2007 | 05:24 PM
jtabraham's Avatar
jtabraham
since your idle lowered after the dealer changed your oil, it would be a good idea to see if they put the correct amount in. Also 900-1000 rpms you were experiencing is too high unless it was during warm-up
Old Jan 12, 2007 | 05:56 PM
Chad68's Avatar
Chad68
What ugly noise?
When it's warmed up, mine idles around 700.
Does anybodies engine make like a boom type sound when they first fire it up when the engine has sit overnight and it's cold?
I never noticed this boom sound before the shortblock got switched out but now I notice this noise. Just don't know if it could be something or if now I notice every little thing, than I did before and I'm just being paranoid.
Old Jan 12, 2007 | 06:24 PM
UGOTZ'D's Avatar
UGOTZ'D
i wouldn't worry about it my idle is right around 700 rpms amd i have noticed the needle likes to fluctuate a little (we're talking 100 rpms up or down)
Old Jan 15, 2007 | 04:23 AM
DustinZ33's Avatar
DustinZ33
thanks for all the help. I guess I was just worried because the car is new and I never noticed that happened before.
Old Jan 15, 2007 | 07:04 AM
mikead_99's Avatar
mikead_99
It sounds like prior to your oil change your idle had been bumped up with an ODBII tool, or may your throttle position sensor wasn't calibrated. I think they probably just gave you a "corrective" action either doing the tps cal or resetting idle to default. FWIW, I added about 75 rpm to the default with an ODBII tool and my idle is completely smooth now, although it is above 700 rpms now. That's the whole deal with ODBII compliance, idle is set to as low as possible to reduce emissions, unfortunately this doesn't mean the best idle quality for us.
Old Jan 15, 2007 | 09:42 AM
DaveZ06's Avatar
DaveZ06
Why not get a reflash and raise your idle to like 1200... cooler idle sound and less chance of stalling
Old Jan 15, 2007 | 02:52 PM
Q45tech's Avatar
Q45tech
And almost double the idle fuel consumption!
liqalu04
Jan 2, 2022 12:58 PM
05UltraYellow
Sep 24, 2015 05:41 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Darkspy
Sep 7, 2015 09:09 PM
