Re: 2006 350Z Engine Recall
Originally Posted by raymondcleung
went to the dealer, they admit there's oil consumption problem. however, when they are doing test w/ centeral tech, they claim 0.5 quart every 1000miles is NORMAL!!! WTF.... and even the service manager agrees that can't be normal but the dealer can't do anything about it. just tell me to keep an eye on the oil level. He also alleges Nissan knows there's a problem but don't have solution to it. Nissan is just putting us to our risk after warranty expires!!!.........................and Counsumer Affairs allege there's no recall due to not enough complaint!!!
SO ALL 350Z OWNERS SHOULD FILE A COMPLAINT ON THE EXCESSIVE ENGINE OIL CONSUMPTION!!!
FYI, as you already know, that is not normal.
[Edit]
https://my350z.com/forum/engine-and-drivetrain/232332-revup-oil-consumption-tsb-and-discussion.html
I have 7000 miles now on my '06. Have had 2 oil changes and I've driven 1000 miles since the second change. I have averaged 0.5 quart per 1000 miles since new. I drive about 1000 miles a month, so every 3000 miles/3 months I do an oil change. My low oil light never comes on, no pinging or rattling, and the pressure gauge always works/reads normal, high under load/low at idle.
Question, how low does it have to go for damage to occur? Will down 1.5 quarts at 3000 cause a problem? Is there adequate oil to protect the engine as it approaches the 3000 mile change? Thanks.
John
as far as what i know engine oil is for engine lubercation. there's 5 quarts in the engine. so if 1.5quarter out of 5 is out = 30%. That means the engine is not lubercating 30%. what damage do u know that will cause???
Also, I asked the deal and consumer affairs to give me technical support to state how 0.5 quarts every 1000miles is considered as normal. They just deny my request stating they'll not provide that. WTF!
does anyone has a sample writting of lemon law on oil consumption issue???
http://lemonlaw.bbb.org/
Originally Posted by dayz
If you really want a new engine, just drain a little out of the pan before you take it in for the next oil change. But don't do it hot! You will end up losing all the oil.
So I have an 07 with 4400 miles on it. I also have the rattle that sounds like its coming from my Y pipe. I had the Y pipe replaced with no change in the sound. Oil level so far is full and has not changed. Any more 07's with the same issue let me know please.
