What should I do for a LSD SWAP
Old Feb 21, 2007 | 12:51 AM
doreamon50's Avatar
doreamon50
Default What should I do for a LSD SWAP
can someone tell me what I need do and what I need to take out for a LSD swap, my friend just crashed his Z, and insurance is payoff his car, he is asking me do I need any parts. Mine is the base model, and his is the track model. Do I just open the rear diff oil cover and take out the parts, or do I have to remove the whole rear axle ( the middle part that connect the shaft and both side of the axle that links to the wheels?). Thanks
Old Feb 21, 2007 | 01:00 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
is there damage to the rear??? if not i would swap out the whole pumpkin/axles/brakes and all, then you'd have brembo's also
Old Feb 21, 2007 | 01:11 AM
doreamon50's Avatar
doreamon50
haha... he sold is brembo brakes already, I wish he would of told me sooner. no damage on the rear. Do I also need the axle for the swap?
Old Feb 21, 2007 | 01:14 AM
ARMSTRONGARMS
yes you need the axles
Old Feb 21, 2007 | 01:18 AM
doreamon50's Avatar
doreamon50
other thread that I was looking through, people mention something call stub axle, is that the axle that connects to both of the wheels? or is it some other part that I need extra to complete the swap?
Old Feb 21, 2007 | 02:53 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
if the entire housing is fine, just swap the the whole pumpkin.
Old Feb 21, 2007 | 03:19 PM
doreamon50's Avatar
doreamon50
So when I take out the pumpkin, do I need to take out the rear axle also from my friends car to mine, to complete the swap??
Old Feb 21, 2007 | 03:32 PM
Sharif@Forged
Forged Performance
Nope, just unbolt your axles from the output shafts, and drop the pumpkin. The new pumpkin will bolt right up...and reattach the axles.
I am obviously simplifing this. But its a simple swap.
Old Feb 22, 2007 | 12:43 AM
doreamon50's Avatar
doreamon50
oh.. one more thing.. will auto and manuel mades a differece, coz mine is manual, and my friend's car is an auto. Will that be a problem
Old Feb 22, 2007 | 05:42 AM
Sharif@Forged
Forged Performance
They will both fit just fine, but the auto diff has the 3.3 lower final drive. On an NA car, that would you make you really slow.
Old Feb 22, 2007 | 06:11 AM
THE TECH's Avatar
THE TECH
I wasn't aware that you could get the Track model in an auto.
Old Feb 22, 2007 | 06:19 AM
Sharif@Forged
Forged Performance
You cant...hmm. The poster might want to confirm the model type.
Old Feb 22, 2007 | 06:20 AM
MustGoFastR's Avatar
MustGoFastR
You can't. Maybe it's a GT?
At any rate, what was said above is key; you don't want to put the whole diff from an AT into your MT. You'll need to pull both diffs, dissassemble both and swap in just the LSD, which will be very tme consuming and expensive to have done. Not a DIY unless you really know what you're doing. It prob wouldn't cost all that much more just to buy an afermarket diff (which will be much better than the OEM VLSD) and have it installed in your car.
Old Feb 22, 2007 | 06:22 AM
2005daytonaZ's Avatar
2005daytonaZ
so if I were to go to a junk yard and find a Z that had the LSD i could just grab the whole pumpkin and just swap it in? I'm dying to get LSD but dont have the cash to buy an aftermarket unit right now.
Old Feb 22, 2007 | 09:04 AM
MustGoFastR
Yes, just make sure it has the same type of tranny as your car and look for one with little or no rear end damage.
SpartanZ32
Oct 22, 2015 09:36 AM
Paul.
Oct 16, 2015 07:34 PM
SharX59
Sep 27, 2015 09:23 AM
3vilbunny
Sep 13, 2015 12:31 PM
