In desperate need of technical help (wire to disconnect for burnouts in an Auto
Old Aug 5, 2003 | 08:39 PM
  #41
MySunset350Z's Avatar
MySunset350Z
Originally posted by ajk4
look on the back of the fuse panel cover on the drivers side kick plate. there is a diagram of each fuse and its purpose the one you want says "stop lamp" and its a 10a fuse. however, the switch is much better cause you dont have to put in and take out the fuse everytime, and its really simple to make.
thanks for the info
cant wait to try it tomorrow
ill probably have to go with a switch. cause im too lazy for pulling it out everytime i need to get a good burnout.
Old Aug 5, 2003 | 11:20 PM
  #42
12SecZ's Avatar
12SecZ
Yeah it gets real old fast. It should be the third row down and its hard to get too for me, I can't wait to get my switch done.
Old Aug 6, 2003 | 11:52 PM
  #43
MySunset350Z
i just ran my car without the fuse today. i have to admit i had some really really nice burns going.
i didnt get the chance to run it with the fuse in, maybe i got too happy..i dont know. i only got 2 runs in because of how many cars were around, and basically my getting mugged inbetween runs by people wanting to check out the car.
quickest 60 2.15
quickest 1/4 14.15 @ 98.49
shitty track and a 97 degree day
i guess i cant complain too much, only having an intake and grounding kit.
i did see some cars running 8's....very nice.
oh and there was this one kid with his dads vette. in the middle of his run, his top comes flying off and lands right side up. not a scratch on it. what a sight.
Old Aug 7, 2003 | 12:06 AM
  #44
12SecZ's Avatar
12SecZ
no way! I bet people freaked!
97 is just too hot for our Z's my experience is they don't tolerate heat as well as LS1's.
In 70 degree weather with a good launch and a 99 trap you are 14.0 Great 60 '!
Old Aug 7, 2003 | 04:25 AM
  #45
speedracerxx1's Avatar
speedracerxx1
you should use something called a line lock it locks the front brakes/bake brakes/1 brake and so on you can probably get it @ summit racing or a local speed shop for american cars it taps in after the master cylinder to the front/rear brakes or which ever one you want use to have it on my malibu for track night so you dont burn up your bake brakes. wheels are free to spin back brakes not engaged while doing a burnout...... it uses a solenoid with a switch similar to your nitrous setup just two wires and some plumbing.
Old Aug 7, 2003 | 09:09 AM
  #46
MySunset350Z
its not a 1.7 60foot, but its ok for now....and for my first time at the track
Old Aug 8, 2003 | 04:43 AM
  #47
12SecZ's Avatar
12SecZ
1.7 60' was Nitrous bro.
Great job. Addicting isn't it. I want to know more about this domestic line lock and if it works on imports. Sounds perfect!
Old Aug 8, 2003 | 09:29 AM
  #48
MySunset350Z
it is addicting.
i want to get the nitrous hooked up just so i can hit up the track again. i heard about those guys doing a 235 shot...thats just sick. but i did call him up to see what kind of setup we can work out for me.
Old Aug 8, 2003 | 03:14 PM
  #49
12SecZ's Avatar
12SecZ
Yeah ask them what brand, direct port etc, what plugs, wqhat fuel injectors, how they keep their a/f and spark correct at that high of a jetting etc. Inquiring minds want to know and maybe a time slip would help.
FIrst they said 300 shot then 235, I am not convinced a stock fuel pump and injectors/plugs would handle that so tell them to share more data as proof. I share, they share too!
Thanks
Old Oct 7, 2003 | 06:00 PM
  #50
Jspec350z's Avatar
Jspec350z
ajk4 or skidazzle do you lose your brake lights when you hook up the switch like you have described? Is this the same for a 6 speed?
Old Oct 7, 2003 | 09:22 PM
  #51
ajk4's Avatar
ajk4
yes, the brake lights dont work when the abs is turned off, or the fuse is removed from the fuse panel.
Old Oct 8, 2003 | 08:56 AM
  #53
MySunset350Z
yes u do lose ur brake lights when u turn the switch off....but no one has answered weather this mod is for auto only or both manual and auto.
burglapfd
Dec 6, 2020 01:04 PM
350Z_Al
Oct 29, 2020 07:44 PM
Jambo016
Sep 16, 2016 01:08 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
