oil pressure
Old Mar 23, 2007 | 01:09 PM
LvntheZ's Avatar
LvntheZ
Default oil pressure
ive been looking around and found no answer to my ?....
is my oil pressure normal..
its like at 25-30 at idle and like 50 -60 at normal acceleration....
im asking this because i cant rememeber what it was.... i havnt driven the z in like a month and i forgot....
thanks for the help....
Old Mar 23, 2007 | 01:14 PM
QuicksilverZ33's Avatar
QuicksilverZ33
Mine is the same exact numbers...30 at idle 60 -65 wot
Old Mar 23, 2007 | 01:17 PM
Richy350Z's Avatar
Richy350Z
Before my tranny was replaced it used to sit at 60, when floored it used to go up to 120! , but not it just goes from 65-70MAX! , I don't know why
Old Mar 23, 2007 | 01:55 PM
LvntheZ's Avatar
LvntheZ
well at WOT it hits like 90-100 .... but my concern was at idle.... it looked too low to me...
Old Mar 23, 2007 | 09:01 PM
XuperXero's Avatar
XuperXero
I'm in canada, we use the metric system instead of psi.
I think I'm a bit low too... reading less than 1/4 of the gauge...
Old Mar 24, 2007 | 07:50 AM
rockinbboy's Avatar
rockinbboy
it will be high when you first start the car. after driving for a good 5-10 minutes it should be within normal psi levels.
A simple test is this once you are warmed up and been driving:
At 70 MPH, you should be at 2500 RPMs and 60 psi.
Old Mar 24, 2007 | 08:03 AM
halfass872's Avatar
halfass872
I'm having the opposite problem, lol....
https://my350z.com/forum/engine-and-drivetrain/258555-oil-pressure-change-with-new-filter.html
Old Mar 24, 2007 | 08:11 AM
Mike Wazowski's Avatar
Mike Wazowski
20-25 is normal when warmed up and idling
and rockin is right about the 70mph
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
