305 hp NA !!
Old Apr 17, 2007 | 09:24 AM
  #81
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by rocks
When i dynoed my car with megan headers on it, the tq curve on it doesnt jump around. Wierd..
yeah and you have a much lower compression ... 2 totally different engines
Old Apr 17, 2007 | 09:32 AM
  #82
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by Audible Mayhem
my car makes the most power at 12 to 1 AFR. i have a dyno remember
This is interesting to me... IMO when you introduced new pistons into the equation, the combustion chamber must've gotten less efficient. That is why you need more fuel to burn up the O2 you are getting into the cylinder.
Cool stuff, I'll be checking back for updates since you're pretty much my N/A hero right now
Old Apr 17, 2007 | 10:30 AM
  #83
350Z_LEE's Avatar
350Z_LEE
Nice :]
Old Apr 17, 2007 | 12:22 PM
  #84
03BrickyardZ's Avatar
03BrickyardZ
Originally Posted by smellslikecurry
this is one race gas right
I think he's running diesel... It is 15:1 compression...
J/K... i'm pretty sure he's running C16 race fuel.
Old Apr 17, 2007 | 01:03 PM
  #85
gothchick's Avatar
gothchick
Never a waste, if you're a Z enthusiast.
Old Apr 17, 2007 | 02:30 PM
  #86
warmmilk's Avatar
warmmilk
*edit* this was meant to go to the other part of the thread that go moved
Old Apr 17, 2007 | 02:32 PM
  #87
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Please direct your off topic comments to this thread:
https://my350z.com/forum/engine-and-drivetrain/264939-spinoff-of-audible-mayhem-s-305hp-thread.html
do not b1tch about this, I am not censoring anyone.
  #88
dayz's Avatar
dayz
have you compression tested the head? what kind of psi you getting?
Old Apr 17, 2007 | 03:01 PM
  #89
Zexy's Avatar
Zexy
Originally Posted by maximumsportZ
So when's the 125 shot going on ?
BOOOOO.. NO!!
Old Apr 17, 2007 | 03:22 PM
  #90
i8acobra's Avatar
i8acobra
you cant mill these heads more than a total of .010 because the timing cover wont line up on the heads cause it drops them down. you need to raise the compression with pistons or a smaller combustion chamber.
Thanks, that's the info I was looking for. I don't want to buy two sets of pistons, so I guess I'll just go with the Nismo heads (smaller chamber) and drop it back down with pistons when I do the shortblock. I just hope the valve angle on the Nismo heads is the same as stock so I can use my S7 Cams. 'Course, I don't even know if Nismo has '06 heads yet, but I guess I'll find out.
Old Apr 17, 2007 | 06:03 PM
  #91
Audible Mayhem's Avatar
Audible Mayhem
My350z
speaking with Jim Wolf and with Brian Crower, looks like i will have some nice cams here soon.
i will have it back on the dyno too very soon this week to try some new stuff...
Old Apr 17, 2007 | 06:17 PM
  #92
diwun67's Avatar
diwun67
Sweet, can't wait to hear this beast in person
Old Apr 17, 2007 | 06:20 PM
  #93
__jb's Avatar
__jb
Z + Rear Seat
Are you going to have to check the valve clearance again with these new cams, or can they assure you that they are similar enough to the cams you have in now that you don't need to check it again?
Old Apr 17, 2007 | 06:23 PM
  #94
Audible Mayhem
My350z
i am going to take the motor apart again soon and clay it before i get my cams ground. i will do this very soon. probably change the headgasket to HKS and do a couple other small things.
i will be porting out some things (intake manifold) too here soon to see if that helps out.
Old Apr 17, 2007 | 08:23 PM
  #95
ZLadie2000's Avatar
ZLadie2000
still going to the track wed?
Old Apr 18, 2007 | 03:42 AM
  #96
Audible Mayhem
My350z
no, i am going friday though, i have a lot of work to do.
AJ, my tech, is going though, we are going to take Albertos stock block TN time away... (very soon)
Old Apr 18, 2007 | 05:11 AM
  #97
NA&CH's Avatar
NA&CH
I can see it "Performance Factory, taking everyones times away"
Keep it up Jeremy. I can't wait to get something going for my woopde(sp )
Old Apr 18, 2007 | 07:32 AM
  #98
gothchick's Avatar
gothchick
Subscribed~ I, for one, am very interested in Jeremy's R&D efforts. Please keep up the great work! :-)
Old Apr 18, 2007 | 07:53 AM
  #99
rocks's Avatar
rocks
Share your cam specs when you get them.
Old Apr 18, 2007 | 11:33 AM
  #100
RBlover69's Avatar
RBlover69
what time u going ill probably be there to see the NA beast.
