stroker kits...
Old May 21, 2007 | 01:07 AM
thewhiteknight's Avatar
thewhiteknight
Default stroker kits...
does anyone know what the change in power would be with the brian crower 4.15L stroker??
Old May 21, 2007 | 03:09 AM
meatbag's Avatar
meatbag
nope
Old May 21, 2007 | 03:15 AM
Devil Z's Avatar
Devil Z
Negative -25647224576 hp
Old May 21, 2007 | 03:19 AM
Mike Wazowski's Avatar
Mike Wazowski
Old May 21, 2007 | 05:18 AM
QuadCam's Avatar
QuadCam
well.............you should increase the head flow, cam lift/duration, etc to take advantage of the extra cubes. IF you do that, you'll see great gains.....If not, you may only get small peak HP increase, a solid torque bump, and possible a less usuable RPM range.
It all depends on the implementation of the kit. How heavy are the crank, rods, pistons, etc? what's the rod ratio like? piston side loading? too many variables to really say.
Old May 22, 2007 | 03:40 PM
GTM's Avatar
GTM
Vendor - Former Vendor
We had some good success with our GTM 4.24L Stoked engine. Check the thread in my sig
-George
Old May 22, 2007 | 03:42 PM
Kwame's Avatar
Kwame
I have the kit and it will be going in my car soon. I will definitely do a full write up when it is done.
Old May 22, 2007 | 04:16 PM
Julian@MRC's Avatar
Julian@MRC
We are currently installing a 4.15 86.4 mm Kit in an APS powered car.We doing the cams and valves and some mild head work..We will let you know soon.
Old May 22, 2007 | 04:20 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
I am interested to see results as well, I will be looking into this with a low boost setup on a TN.
Old May 22, 2007 | 04:28 PM
Kwame's Avatar
Kwame
Good luck with that project, I am looking forward to the results. I went with the 100mm kit and I am obviously doing an NA build.
Old May 22, 2007 | 05:05 PM
Resolute's Avatar
Resolute
nice. can't wait to see your results.
will
Old May 22, 2007 | 05:22 PM
Kwame's Avatar
Kwame
will
Lol, don't hold your breath.
Quamen
Nitrous Oxide
24
Mar 10, 2006 11:57 AM
BobaFettm
Dec 19, 2005 08:36 PM
dch760
Nov 23, 2005 10:02 AM
cquence 350 [Z]
Apr 26, 2005 02:06 PM
