griding noise in engine bay
Old Jun 2, 2007 | 12:02 PM
350z 6spd's Avatar
350z 6spd
Default griding noise in engine bay
i have an 03 6mt... When the car is cold and i hold the clutch while starting it there is a terrible grinding noise just after the car starts for 2 seconds or so in the engine bay area(most likely trans. area). If i start the car and immediatley let go of the clutch as soon as it starts the noise doesnt happen. This leads me to believe it has something to do with the clutch/trans.
If anyone has any ideas what this may be i appreciate it. Thanks
Old Jun 2, 2007 | 12:15 PM
Ztalker's Avatar
Ztalker
sure it wasn't your starting motor?
Old Jun 2, 2007 | 12:35 PM
350z 6spd's Avatar
350z 6spd
yea, definetley not the starter motor
Old Jun 2, 2007 | 02:52 PM
Fastass350z's Avatar
Fastass350z
possibly your strter isnt disengaging..
Old Jun 3, 2007 | 02:30 PM
350z 6spd's Avatar
350z 6spd
maybe, but then it would probably do it all the time.
throw-out bearing??
Old Jun 4, 2007 | 03:46 PM
350z 6spd's Avatar
350z 6spd
bump...
Old Jun 4, 2007 | 08:30 PM
midlife38's Avatar
midlife38
Default ya what is it
I've Had my 04 in the shop 6 times and the tech said it was the transmission so thery replaced it with a new 6 speed. Ya they thought they fixed it made the say noise as soon as I picked it up. So any Ideas anyone?
Old Jun 4, 2007 | 08:32 PM
z350boy's Avatar
z350boy
Didi they check the clutch's master & slave cylinders??? I had a similiar problem, they replaced the tranny and the clutch's master & slave cylinders. Problem solved!!
Old Jun 5, 2007 | 08:50 AM
HondaKiller's Avatar
HondaKiller
occasionally my Z with do this. I describe it more of a chatter upon starting the car cold.
I've read up on it being a butterfly vavle. If remember correctly it is caused from the oil not circulating fast enough to the top of the block when starting cold. If you search for engine chatter you might find something. Many say it's the transmission/clutch but i think it's a manufacturing flaw that occurs in many Nissan automobiles. A friend of mine has a 2.5 Altima that does the same thing. Also my mom's 3.5 Maxima does the same thing on cold start's occasionally.
Old Jun 6, 2007 | 09:56 AM
350z 6spd's Avatar
350z 6spd
maybe, my car just started doing it.
Obadabot
Jun 18, 2023 11:31 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
