High-pitched sound from engine compartment
Old Jun 19, 2007 | 10:50 AM
geomark's Avatar
geomark
Default High-pitched sound from engine compartment
Any idea what this could be? The key is in, the engine is off and I hear a high pitched sound like a door-beep but it's a lower tone.
Thx.
Old Jun 19, 2007 | 10:51 AM
03BrickyardZ's Avatar
03BrickyardZ
Thx.
IT'S A BOMB!!!!
I dont know what that could be.
Old Jun 19, 2007 | 11:23 AM
cheshirecat79's Avatar
cheshirecat79
That is the single best response I've seen on any message board.
Ever.
Old Jun 19, 2007 | 11:50 AM
DJMatrix1067's Avatar
DJMatrix1067
ah yes im familiar with said noise.
it is the micromotor inside your throttle body adjusting.
key is in and in the "on" position, however engine is off.
Old Jun 19, 2007 | 11:54 AM
Billhyco's Avatar
Billhyco
IAC - IDLE AIR CONTROL MOTOR / Nissan may call it an AIS, not sure
fix = remove the key
Old Jun 19, 2007 | 02:09 PM
VO...'s Avatar
VO...
Administrator
I believe it's your coil pack, which replaces the old school distributor cap design. Don't leave your key in that position too long or you'll burn the pack out. I believe this is what it is. I could be wrong.
Old Jun 19, 2007 | 02:37 PM
DaveFunction2ND's Avatar
DaveFunction2ND
Yep Throttle Body.
Old Jun 19, 2007 | 03:18 PM
stormcrow's Avatar
stormcrow
i have a high pitched noise, too... but, only when i let off the throttle when under high boost... i *think* it's my blow off valve... PPPPPPSSHHHEEEEEEEEWWWWW!
Old Jun 19, 2007 | 03:21 PM
SirSpeedyZ's Avatar
SirSpeedyZ
^^^ good call
Old Jun 19, 2007 | 03:38 PM
Tenac1ousZ's Avatar
Tenac1ousZ
if it's the hissing sound when the key is in the "on" possition but the engine is off, then it's the throttle body. I'm almost 100% sure. To check, open your hood, turn the key to the "on" position while engine is off, and step on the throttle. You'll hear it working
Old Jun 20, 2007 | 06:54 AM
blackstealthz's Avatar
blackstealthz
Originally Posted by 03BrickyardZ
IT'S A BOMB!!!!
Old Jun 20, 2007 | 06:56 AM
jtabraham's Avatar
jtabraham
I thought Nissan and most new cars don't use servo motors to control idle speed anymore...The ECU just makes small adjustments to the throttle
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
samansharif
Sep 25, 2015 12:31 PM
