Update: My Build, Ultimate Goals & 1 CRAZY Day in Utah
Old Jul 2, 2007 | 08:30 PM
  #61
THE ROADSTER's Avatar
THE ROADSTER
Roadster ha!!!!!um um um, thank you BamBam for the test. Good luck, be safe and make us proud of our FI roadsters.
Old Jul 3, 2007 | 06:09 AM
  #62
DanielW's Avatar
DanielW
Originally Posted by r0mey
best of luck to you brent
another hot chick on romeys avatar. nice...
Old Jul 3, 2007 | 06:39 AM
  #63
MDaniel22's Avatar
MDaniel22
Simply Sick! Good luck man!!
Old Jul 3, 2007 | 06:51 AM
  #64
RKnight's Avatar
RKnight
Good Luck! I'm sure you will be fine.
Old Jul 7, 2007 | 05:48 AM
  #65
4SHIZZIL's Avatar
4SHIZZIL
Put that suspension on the ground...beef up the front bumper screws....I also recommend cheap tape over the bumper and hood line....
May God be with you on your run...we expect success and video...lol!
Old Jul 7, 2007 | 06:12 AM
  #66
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
what else can I say that hasn't been - you're in a league of your own man, huge congrats go out to you, and wish you the absolute best of luck
Old Jul 7, 2007 | 12:36 PM
  #67
BamBam's Avatar
BamBam
Thanks guys.... But it looks like something has come up with the overall safety of the engine.
Not sure we can run it the way I intended. Still trying to work out details but at the moment it is not looking good. I might still run, but it would be with limited power and nowhere near where the engine should be running. So the chances of hitting 200 mph are looking slim at this point.
Suffice it to say I am extremely disappointed for something like this to come up at such a late point in the execution stage.
--B
Old Jul 7, 2007 | 01:30 PM
  #68
redman333's Avatar
redman333
Hey let us know if it gets pushed back at all. Especially to some time in august cause then I can make it out there to watch.
Sorry to hear about the engine issues. Hope eveything works out for you. You know what would be nice though is that even with the limited power you still hit 200.
Old Jul 7, 2007 | 01:36 PM
  #69
hunter6's Avatar
hunter6
Thumbs up
Originally Posted by rocks
Considering the Z was not wind tunnel tested past 160 mph you may die.
I love it when folks get right to the point
At any rate good luck and stay safe!
Old Jul 7, 2007 | 01:37 PM
  #70
IIQuickSilverII's Avatar
IIQuickSilverII
what happened to the engine?
Old Jul 7, 2007 | 01:58 PM
  #71
350Z84's Avatar
350Z84
Also would like to know what happened? Hope that you get it up and running before the event. And, if you do good luck with everything and be safe!
Old Jul 7, 2007 | 02:10 PM
  #72
ZU L8R's Avatar
ZU L8R
Viper Sellout
My guess would be the engine is fine but he needs Charles' dual intank pump setup. Am I right?
Old Jul 7, 2007 | 04:22 PM
  #73
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
At least. It's unforunate that we found this out yesterday, but at least we found out, and can monitor as we go, and also reduce boost to increase our chances of success. The issue isnt necessarily the absolute capacity of the fuel system, although we are bumping up against that as well.
The issue is that under an extended WOT pass WITHOUT shifting, or any pause, the fuel system will start to drop pressure. It gets worse, obviously, with higher boost pressure. Keep in mind that Brent's stroker is making the same power we make with 20psi, with just 15psi!
This is something that nobody would ever see on the street, or even road racing their car, since you are constantly shifting and decelerating, and allowing the fuel system to catch up, for lack of a better word. In a road racing situation, the max duration of WOT without shifting is less than 8 seconds...if that. At big tracks like Road Atlanta, its probably more like 5-6 seconds, and well within the fuel systems capabilities.
It will be interesting to see if something like the CJM Stage III twin pump can not only provide fuel for xxx whp, but also provide fuel for an extended period of WOT without shifting or decelerating.
BamBam is trying something that has never been done, so we are all learning as we go. I am just sorry it happened under such a difficult time constraint.
So, Brent is on his way back home in his insane looking roadster.....and I will be joining him at the Salt Flats next week.
Old Jul 7, 2007 | 04:36 PM
  #74
350Z84's Avatar
350Z84
Hmmm, interesting, but makes complete sense now. Once he hits 200 MPH he should only have to hold it about 20 seconds though right?
Old Jul 7, 2007 | 07:38 PM
  #75
ZU L8R's Avatar
ZU L8R
Viper Sellout
Just glad to hear his motor is fine. With all the bad luck he's had it just wouldn't be right for something else major to go wrong. It's all one big learning process
Old Jul 7, 2007 | 07:55 PM
  #76
rcdash's Avatar
rcdash
What about tuning and running a super octane fuel? You'd require less fuel that way. Maybe a race gas/methanol mix? You wouldn't want to expose the piping to that all the time but for a short period it should work...
EDIT: another possibility to consider is having two cars run in tandem, one in front of the other so that BamBam's car can draft till the last leg of the top speed run - then he only needs to floor it for about 20 secs to reach his goal. Just a thought if Sharif is going to have his car out there also...
hope you guys figure something out! gl
Old Jul 8, 2007 | 05:51 PM
  #77
Nowell's Avatar
Nowell
National Z Club
He will already be running C16. The 200 mph run doesn't have to be for a sustained time. They are hooking our cars up with all the telemetry hardware they need to monitor. He still might be able to break it but we will see.
Old Jul 9, 2007 | 10:34 AM
  #78
DanielW's Avatar
DanielW
the suspense!!!
Old Jul 9, 2007 | 11:25 AM
  #79
TENGAI's Avatar
TENGAI
Damn. Sorry to hear bro. I know you were going all in for this run and did so much work to the car to get it there.
I'm sure it's still going to go down in the record books. Hopefully we'll see more out of her before the season's over, but worst case, you can always plan on saddling up next year for another run...
Sharif -
Do you think the CJ twin-pump will get the fuel levels stable for a 20+ second run? If Brent's Bosch pump / twin Walbro setup isn't enough, then what? External cell and massive fuel pump(s) I'm guessing... But at that point, streetable goes out the door.
Old Jul 9, 2007 | 11:39 AM
  #80
Sharif@Forged
Forged Performance
with 550whp+, I think we have the power to hit 200mph, but now we are pushing a much heavier car through the air, so it's going to be tricky.
In regards to a solution, I think the easier approach would be a voltage/boost based booster, that would kick in after about 12psi or so, to insure we have more flow out of the existing pumps.
Other than that, its fuel cell time, but I really doubt Brent is going to want to ditch his AV gear in the trunk.
