ECU code - not on the list, i checked :D
Old Jul 24, 2007 | 05:20 PM
scratch137's Avatar
scratch137
Default ECU code - not on the list, i checked :D
Threw this code:
P1283 - Manufacturer control fuel air metering
Any help would be nice...
Old Jul 24, 2007 | 07:09 PM
scratch137's Avatar
scratch137
Up, please can anyone gimme some insight
Old Jul 24, 2007 | 07:26 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
did you recently oil your intake?
sounds like a maf code, but i dont really know.
Old Jul 24, 2007 | 08:55 PM
dovla's Avatar
dovla
from SM
DTC No.: P1273 (Bank 1) P1283 (Bank 2)
Trouble diagnosis name: Air fuel ratio (A/F) sensor 1 lean shift monitoring
DTC detecting condition: The output voltage computed by ECM from the A/F sensor 1 signal is shifted to the lean side for a specified period.
Possible Cause:
 Air fuel ratio (A/F) sensor 1 heater
 Fuel pressure
 Injector
 Intake air leaks
Old Jul 24, 2007 | 09:06 PM
skidmarks's Avatar
skidmarks
what do you have that is greddy? getting a little ahead of yourself on the trade huh?
Old Jul 25, 2007 | 06:18 AM
Q45tech's Avatar
Q45tech
You might check the inside of bank 2 cats [check both just to be sure if #2 is ok] for melting as this code occurs on Titans and others and that is the usual outcome if after replacing O2 the code comes back.
Old Jul 25, 2007 | 09:02 AM
scratch137's Avatar
scratch137
doyla, what does that mean lol. and how do i fix it
Old Jul 25, 2007 | 09:28 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
probably running rich/lean and tuning should get rid of it
Old Jul 25, 2007 | 10:18 AM
jpc350z's Avatar
jpc350z
Possibly a bad O2 sensor which is used by the ECU to select the correct injector pulse width for A/F ratio that makes the pollution police happy..??
Old Jul 25, 2007 | 10:22 AM
scratch137's Avatar
scratch137
lol sorta random but when you said pollution police, like a dinger went off in my head and just started think how the nickname "popo" would be perfect for them. lol.
Old Jul 25, 2007 | 10:24 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
do you have test pipes?
Old Jul 25, 2007 | 11:32 AM
scratch137's Avatar
scratch137
yes i do. but i had them for a while w/ no problems, then the CEL randomly came off, i got it cleared a few times, and reset the ecu a few time and it would always come back on until one time it just went off for a while after i filled up some gas (i doubt the gas had anything to do with it, i think it was just coincidence) then it stayed off till recently.
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
