LSD Question
Old Aug 12, 2007 | 04:41 AM
silver nismo's Avatar
silver nismo
Default LSD Question
I will make it verey short if this is the wrong section pls Mod. relocate..
I did the Diff swap mine is a manual and i swaped it with an Auto 1 so i get a longer gear ratio.. I wanted to install the LSD for Auto cross events how ever I can only find the manual LSD diff. in ther words the short ratio. Is there an Auto LSD so i can keep the long gear ration?
Old Aug 12, 2007 | 08:42 AM
i8acobra's Avatar
i8acobra
The LSD is the same for both the 6MT and the auto. The difference is the ring and pinion. The ring and pinion from the auto will bolt to any LSD.
Old Aug 12, 2007 | 09:31 AM
jonnylaw's Avatar
jonnylaw
axel stubs (flanges) are different for auto with open diff and 6 m/t. If u have open diff now the quaife atb would work with you flanges, if u have h flanges that come with the oem vlsd, than the nismo or cusco or tomei would work without buying new flanges ($125 each)
Old Aug 12, 2007 | 10:06 AM
i8acobra's Avatar
i8acobra
From what I understand, it doesn't have anything to do with whether the car has a 6MT or auto. The difference is between the open diff case and the VLSD case. The only difference between 6MT and auto cars is the gear ratio.
Old Aug 12, 2007 | 11:40 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Thats not correct. Not only is the ring gear different on the auto, it is also thicker, and the ring gear shelf on the diff is 10mm lower, so no, they are not interchangeable at all.
Quaife makes a diff for the automatic's.
Old Aug 12, 2007 | 12:01 PM
i8acobra's Avatar
i8acobra
Well, that's just f'in stupid.
Nissan
Old Aug 12, 2007 | 12:06 PM
Sharif@Forged
Forged Performance
Nissan
Yeah, tell me about it.
Old Aug 12, 2007 | 04:03 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Exclamation
just installed the quaife lsd for a auto rear diff for my 6MT setup...works great...order new bearings from nissan, contact jim @ turbo toys for standrad stub shafts if your current rear diff is factory LSD (diff stub shafts)...
I'll be happy to give you pointers if you go through with it.
jim@ turbo toys:
813-695-6664
TODD
Old Aug 12, 2007 | 05:43 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
not true at all
the diffs are absolutely different between MT and auto cars. As I recall you can install an auto into a manual pumpkin but not vice versa
I know Quiafe does an auto version, so does Cusco - those are the only 2 I know of
Old Aug 12, 2007 | 06:00 PM
OCG35's Avatar
OCG35
AT Quaife may not be available any longer... I know AutoTech (previously Quaife America) no longer carries them... possibly a vendor/dealer might have one in stock but all that I consulted order direct from Auto Tech as needed.
Old Aug 12, 2007 | 06:45 PM
helldorado's Avatar
helldorado
I took some shots this afternoon highlighting the difference between th 3.357 and 3.538 as well as the VLSD and open diffs. I should have them up later this week.
I'm 99.9% sure those are the only two options for the 3.357.
Axle stubs are independent of whether it is a 3.357 or 3.538, they depend on the differential type. Open diff has equal length stubs and VLSD has unequal.
Old Aug 12, 2007 | 10:59 PM
Vader007's Avatar
Vader007
Dont give advice when you clearly have no idea what you are talking about!
Both Quaife and Cusco make LSD's for the auto.
Old Aug 12, 2007 | 11:52 PM
silver nismo
Thanx a lot for all of you and that has been a great leaarning sesion...
Sharif thanx for the valuble i9nfo and 350zDCalb thanx for the help and the contact reff. I guess this sort me out now and Quaife it is.
Old Aug 13, 2007 | 06:47 AM
jonnylaw's Avatar
jonnylaw
good choice with the quaife. I definetly enjoy mine!
Old Aug 13, 2007 | 01:13 PM
OCG35's Avatar
OCG35
+1 as do I!!!
Old Aug 13, 2007 | 01:14 PM
OCG35's Avatar
OCG35
are you sure Quaife AT can still be found?...
Old Aug 13, 2007 | 02:30 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
How did you get that info? Did you contact Quaife (AutoTech) directly? The reason I ask is because the auto diff for the 350Z/G35 is still listed on their website. I realize, of course, that it's possible they have not updated the website yet. But I'm curious.
I really hope they don't stop making the A/T version of their diff. That was the diff I was planning on getting in the future for my build project.
Old Aug 13, 2007 | 02:50 PM
Sharif@Forged
Forged Performance
We have ordered the auto quaife diff recently, and they gace me no indication that it was being discontinued. I should call to double check.
Old Aug 13, 2007 | 10:29 PM
silver nismo
well i whent and spoke to the shop that I order from and it appeared that they deel with cusco in a couple of parts so he picked the cusco catalog and ordered 1 for my z... so it was a cusco not a quaife in the end..
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
Alexreyes
Sep 30, 2015 11:30 PM
