Trans noise
Old Sep 26, 2007 | 11:59 AM
rgdodson54's Avatar
rgdodson54
Default Trans noise
My 06, Track model, with the clutch out, in neutral has bearing noise, similiar to bad input shaft noise. the dealer said "Nissan used alot of straight cut gears in the tranny and they make alot of noise". Sounds doubtful to me, any help would be appreciated.
Old Sep 26, 2007 | 12:18 PM
06Gcoupin's Avatar
06Gcoupin
Its the throwout bearing, its very noisy in our cars, notice how the sounds go away when you push the clutch in? Unless the car develops driving issues, such as excessively notchy gearbox, and gear grinding, you should be ok.
Old Sep 26, 2007 | 12:50 PM
Datapimp's Avatar
Datapimp
Think of it as an undocumented feature. That's what I do and I now sleep better at night.
Old Sep 27, 2007 | 06:11 AM
chrishughes's Avatar
chrishughes
I took mine in for the same reason and they replaced the transmission
Old Oct 4, 2007 | 08:31 AM
Ryan NJ's Avatar
Ryan NJ
I have the whistling noise only on the highway and it gets loud at 80mph with like a neutral throttle input. Is there any way to quiet this down?
Old Oct 5, 2007 | 07:21 AM
mitsurs01's Avatar
mitsurs01
what is the remedy to this? I have the noise too. Would replacing the clutch fix it?
Old Oct 15, 2007 | 08:33 AM
eyeSea's Avatar
eyeSea
I too wonder would replacing the clutch fix this?
Old Oct 15, 2007 | 10:19 AM
toy4two's Avatar
toy4two
yes the clutch kit will come with new bearings
Old Oct 15, 2007 | 10:37 AM
Ryan NJ's Avatar
Ryan NJ
I had the dealership replace the clutch and the entire trans with it and I have the same noise I did to begin with. I really think it's just inherent with these cars. My real question is what sound deadening has anyone done to remedy the situation as parts will not fix a thing.
Old Oct 15, 2007 | 03:59 PM
Vencer23's Avatar
Vencer23
have the exact same thing mentioned above: whistle at neutral throttle input while at highway speeds. You accelerate just a bit and the sound disappears, only to return the instant the engine is no longer under stress. Only thing I have found that works is to upgrade stereo and turn up the sirius.
Obadabot
Jun 18, 2023 11:31 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
