Tranny conversion
Old Oct 10, 2007 | 06:29 PM
blck350's Avatar
blck350
Default Tranny conversion
How hard is it to change a AT to a MT on a Z... Is it possible
if possible how much does it cost for the tranny and parts to convert(pedals and ect)
If anyone has done this before i would really appreciate input or advice like if its worth it not worth it
Old Oct 10, 2007 | 06:36 PM
page04Z's Avatar
page04Z
I have never done it on a 350z but I'm assuming its about as hard as the one we did in my 240sx.
AT to MT is good because you wont need the ECU like you would going from MT to AT.
In some cases the car doesnt have the hole punched for the clutch cylinder, so You have to drill a hole through your firewall at [xx] size, then drill the 2 holes for the bolts. You gotta pretty much rip the bottom part of the dash apart to squeeze your drill and tools up there.
Swap trannies and run your hard lines, now would be a good time to upgrade to a SS braided clutch line. You will probably need new interior parts as you'll have the automatic parts.
Also you will probably need the MT driveshaft, along with a new clutch and flywheel.
Its hard and time consuming. It also takes either a lot of mechanical knowledge OR a lot of money. In the case of a 350z, you're going to need a lot of money more than likely.
Old Oct 10, 2007 | 06:48 PM
burntZ's Avatar
burntZ
autotrader.com ?
sell current Z
buy MT Z...
Search ResultsWe found 2,642 Nissan listings [manual 350zs]
Old Oct 10, 2007 | 07:06 PM
XIceDragonX's Avatar
XIceDragonX
keep it auto and put a bunch of the g35x all wheel drive sedan's drive train up front and make your Z into an AWD model.
Old Oct 10, 2007 | 07:09 PM
SuperBlack350z's Avatar
SuperBlack350z
it's not worth it. Right now the z still have good value. Mine as well trade it in for another one then having a hacked up one.
Old Oct 10, 2007 | 07:46 PM
jonnylaw's Avatar
jonnylaw
1. Possible.
2. LOTS of money
3. Not worth it (unless ur car is already so "built" that your money is invested in that car; i.e. fully built engine, turbo setup, all the breathing mods, etc. where trading it in/selling it does not make economical sense b/c the a/t is so far from stock).
A LOT of fabrication work (It's not a matter of just swapping trannies there's a lot more that needs to be done like cutting your cabin to make room for and fabbing mounts for the shifter, hand brake, etc.), and there will still be some issue(s) no matter how clean an conversion imo. For instance, no matter what, ur transmission light will always be on (the solution here being to cover over the tranny light area inside the guage)--small things like that and big things like spending LOTS of $$$$$$$$$
IF ur that serious about wanting a 6 m/t tranny, it will be more cost effective and "complete" if you just sell/trade-in ur a/t and buy a m/t, like many others have already said.
Im too lazy to search right now, but there are a some threads on AT to MT conversions that have been done..There's some interesting stuff there, I think it was GTM that did a couple but dunno.
Old Oct 10, 2007 | 07:51 PM
Oleg's Avatar
Oleg
GTM did it on Gurgen's G35 sedan. GTM has a thread on it in the E/DT/FI section, but I'm too lazy to search for it. Not worth the $$, may as well trade cars.
Old Oct 10, 2007 | 08:04 PM
jonnylaw's Avatar
jonnylaw
I drank some green tea:
https://my350z.com/forum/showthread....=GT+conversion
Dsowe
Feb 17, 2021 10:38 AM
seagrasser
Oct 11, 2015 03:27 PM
Ace2347
Sep 22, 2015 03:12 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
