Baseline Dyno...254whp
Old Jan 28, 2008 | 12:43 PM
ABL 2 FLY's Avatar
ABL 2 FLY
Default Baseline Dyno...254whp
Well I just picked up another 350z. This one is bone stock (other than popcharger) with over 77,000 miles on it. We ran our first run and made 246whp then made 250 and a few later made 254whp. I was expecting 240whp at the most so this really was a surprise. Has anyone seen this type of result. On Dynojet dyno. We just made 248ft/lbs and 255whp. Keep in mind this is a 2003.
Old Jan 28, 2008 | 01:14 PM
Get_Zwole's Avatar
Get_Zwole
impressive numbers
Old Jan 28, 2008 | 02:08 PM
bbs350z's Avatar
bbs350z
happy dyno?
Old Jan 28, 2008 | 02:11 PM
chromesilver6's Avatar
chromesilver6
Nah, everyone knows 03'a are the best. hehe. Nice numbers. I need to dyno mine. It pulls on cars you wouldnt think it should.
Old Jan 28, 2008 | 02:57 PM
gabez33's Avatar
gabez33
cough cough, can u say HR buddy
Old Jan 28, 2008 | 03:05 PM
Fairly Z's Avatar
Fairly Z
I'm interested to Dyno my car. VQ35DEV2 FTW! (2006.5)
Old Jan 28, 2008 | 03:06 PM
SniperHunter's Avatar
SniperHunter
It's true what they say, the VQ only grows stronger as it gets older. Like a Siberian hunter. Or the Incredible Hulk.
SuperBlack350z's Avatar
SuperBlack350z
LOL
Old Jan 28, 2008 | 03:49 PM
ABL 2 FLY's Avatar
ABL 2 FLY
new numbers 261whp 251ft/lbs
Old Jan 28, 2008 | 05:08 PM
ke0ki2k's Avatar
ke0ki2k
2 explanations.
1: its running more than a popcharger.
2: youre blowing straight oxygen into the intake during the dyno run
Old Jan 28, 2008 | 05:18 PM
chefsz's Avatar
chefsz
possible ecu reflash you do not know about?
man 261 rwhp that's nuts.
if true all the more power to you.
off topic but what are the changes between 06 and 06.5?
Old Jan 28, 2008 | 05:22 PM
RJ_KC's Avatar
RJ_KC
some airbag change is the difference from 06 to 06.5 iirc
Old Jan 28, 2008 | 05:23 PM
craigo'sznprgrs's Avatar
craigo'sznprgrs
Can u say correction factor of say 1.1 or higher, lol.
Ecu reflash, not a big believer in the factory freaky VQ myths. There has to be more done. May even be cammed.
Old Jan 28, 2008 | 05:25 PM
ke0ki2k's Avatar
ke0ki2k
itd be runnin more than 261 if it was cammed wouldnt it? maybe? guess it depends on the cams...
Old Jan 28, 2008 | 07:04 PM
ABL 2 FLY's Avatar
ABL 2 FLY
The car is bone stock.. no cams no nothing. There was no smoothing or correction on the chart but when I emailed it and brought it up on my file I had an auto correction on 1. I actually lost .1 whp with the correction. Will post file with 0 correction if needed. Remember we started at 246 and gained 15whp with repetition
Old Jan 28, 2008 | 07:13 PM
shadykilla717's Avatar
shadykilla717
Can I dyno my HR on your dyno?? lol.
Old Jan 28, 2008 | 07:23 PM
ke0ki2k's Avatar
ke0ki2k
stock other than a popcharger yeah? double check that it has no plenum spacer or test pipes! lol
Old Jan 28, 2008 | 07:39 PM
ABL 2 FLY's Avatar
ABL 2 FLY
We have dyno tested a 2003 track model with just a popcharger and saw 237whp... This one was first 246whp then 250.. until we hit 261. No correction was added. We just did run after run. I would agree that the dyno was off of correction was used but under the same condition (a little hotter temp outside) we had a lower result. The car has no test pipe or chip. The redline is also stock. The dyno was done indoors in an A/C shop. Temp normal room temp.
Old Jan 28, 2008 | 08:47 PM
singh's Avatar
singh
_______________
For an 03 to have 261whp is just insane.
Post the 261whp dyno chart and then somebody overlay a stock 07 dyno chart and let's compare!
rocks's Avatar
rocks
Funny I made 236whp on my low compression NA motor on saturday playing with it on the dyno. It was the highest run of the day but I have to fix a bad o2 sensor. This was also on a mustang dyno 4500 ft above sea level.
