Oil temp gauge location
Old Sep 10, 2008 | 11:02 AM
cbr900son's Avatar
cbr900son
Default Oil temp gauge location
Where is the best place to hook up a oil temp gauge. The instructions suggest a brass T by the oil pressure sender. Tho i got to admit im not even sure where that is located. Any advice?
Old Sep 10, 2008 | 11:06 AM
JasonZ-YA's Avatar
JasonZ-YA
mine..
i bought an oem pan off of a member for like 25 shipped and had the work done, so i wouldnt have any down time..
https://my350z.com/forum/engine-driv...sor-mount.html
Old Sep 10, 2008 | 11:23 AM
terrasmak's Avatar
Get a Greddy oil pan or JWT pan spacer and use the turbo oil return port.
If you need the gauge, they extra quart won't hurt.
Old Sep 10, 2008 | 11:43 AM
coachk's Avatar
coachk
The oil pressure sending unit is right underneath(sorta) the oil filter. I put my oil temp gauge in my oil pan.
Old Sep 10, 2008 | 02:40 PM
cbr900son's Avatar
cbr900son
Guess ill see about putting it in the pan. Wonder if i can just drill and tap a hole or if i need to have something welded in.
Old Sep 10, 2008 | 07:53 PM
SpoilsofWar's Avatar
SpoilsofWar
Mine is in the pan, located right next to the turbo oil drain line return. That way, I figure I am getting a sample of the hottest possible oil in the system (just came back from hot turbo).
Old Sep 11, 2008 | 05:32 AM
gothchick's Avatar
gothchick
Ran my sending unit through my AAM oil pan spacer.
Old Sep 11, 2008 | 09:44 AM
coachk's Avatar
coachk
Just drill and tap.....
Old Sep 11, 2008 | 02:09 PM
cbr900son's Avatar
cbr900son
Guess ill figure which route ill be going soon 500 miles till oil change due.
Old Sep 11, 2008 | 09:32 PM
JasonZ-YA's Avatar
JasonZ-YA
the oem pan is to thin to just drill and tap.......
thats why i had a bung for added thickness welded in..
-j
Old Sep 11, 2008 | 11:40 PM
cbr900son's Avatar
cbr900son
Yeah. I was a little worried bout the thickness figured a spacer would be the way to go. Just need to deicde which one I want.
Old Sep 12, 2008 | 05:19 AM
coachk's Avatar
coachk
-j
I did not know that.....I have the APS pan. Never compared the 2 pans, but the APS one is pretty thin too.
Old Sep 12, 2008 | 08:21 AM
SpoilsofWar
The stock pan is stamped steel. The APS is cast aluminum. The APS is a lot thicker.
No way you'd be able to get away with just drilling and tapping the stock pan, you might get 1 or maybe 2 threads out it its thickness.
For clarification purposes, mine is "in the pan" but I use an AAM oil pan spacer.
Old Sep 12, 2008 | 10:04 AM
4SHIZZIL's Avatar
4SHIZZIL
if you did drill the stock oil pan you would need a way to mount a union in the pan..seal the heck out of it with RTV (high temp) then mount the sensor to the union... bolts on boths sides...
if I had the chance or same situation....id buy an oil pan spacer because it servers to purposes....more oil (cooler eng) non permanent mounting spot of accessories.
gl
Old Sep 12, 2008 | 06:22 PM
rcdash's Avatar
rcdash
You could just use an oil filter sandwich adapter. I have 2. Mocal for the oil cooler. Greddy for the oil pressure and temperature sensor. The Greddy unit has 1/8" BSP not NPT ports, but it's very easy to tap it with a 1/8" NPT tap.
No messing with the oil pan necessary.
Old Sep 13, 2008 | 06:49 AM
coachk's Avatar
coachk
Damn Raj 2 sammich's.
Old Sep 13, 2008 | 04:18 PM
rcdash's Avatar
rcdash
easy
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
