Powerlab Spacer Install Idle Problem
Old Mar 10, 2009 | 04:49 PM
s31t8n8's Avatar
s31t8n8
Default Powerlab Spacer Install Idle Problem
Ok so i just installed the Spacer and when i turned the car on the rpms shot up to about 4k then dropped below 1k and then stalled. I checked maf and its fine, didtn hear any leaks. I reset the ecu, checked all the hoses and theyre in the right place and secure. I can turn the car on and rev it but then when i stop revving it stalls.
any ideas?? thanks!!
Old Mar 10, 2009 | 05:17 PM
FairladyBlue's Avatar
FairladyBlue
if all else fails uninstall the spacer and see if the problem still exists then install again or not
Old Mar 10, 2009 | 05:51 PM
dmplaya786's Avatar
dmplaya786
check all hoses again make sure the rubber part around the oil cap didnt get caught inbetween or anything else...
Old Mar 10, 2009 | 06:13 PM
s31t8n8's Avatar
s31t8n8
I checked all the hoses and everything is where it needs to be and properly secured. I also removed my intake and checked the tube, maf, and throttle body and everything is fine. I gave up for now cuz it dark and cold and raining. I disconected the battery and am going to leave it overnight.
when i was moving the car out of the garage i had to turn it on so i could drive up the driveway again, and when i was doing it i really had to give gas so it wouldnt stall out. It doesnt seem like a fuel problem because i can go as long as it i really give it gas.
edit: i was going to do a diy on the install too lol. good thing i didnt otherwise it would have sucked
Old Mar 11, 2009 | 08:11 AM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
If you have an air leak between the spacer / plenum that could cause it to stall out but shouldn't cause it to rev that high at start up.
Old Mar 11, 2009 | 08:54 AM
s31t8n8's Avatar
s31t8n8
heres a vid of the rpms i just took. im gonna start taking everything apart now and hopefully i find out whats wrong
http://s258.photobucket.com/albums/h...t=MVI_1705.flv
Old Mar 11, 2009 | 09:31 AM
s31t8n8's Avatar
s31t8n8
ITS HEALED!!!!!!!!!!!!!!!!!!!!!!!!!! it was a leak after all.
QUOTE=dmplaya786;7057666]check all hoses again make sure the rubber part around the oil cap didnt get caught inbetween or anything else...[/QUOTE]
That was the problem, the stupid rubber ring was caught under the spacer. If it werent for you i probably would have missed that. Thanks man!!!! let me know where to send the beer
THANKS FOR ALL THE HELPS GUYS!!
Old Mar 11, 2009 | 09:46 AM
OCG35's Avatar
OCG35
^^^ it’s a common mistake when installing spacer... it’s the very first thing to check when you have problems...
It’s always best to remove the collar until everything is buttoned up and running smooth. (Should be a part of install instruction Justas a precaution).
Old Mar 11, 2009 | 01:44 PM
finalforce's Avatar
finalforce
Nice! How is the difference w/the spacer? Powerlab 3/8" right?
Old Mar 11, 2009 | 02:04 PM
s31t8n8's Avatar
s31t8n8
yep 3/8 spacer. I can definitely notice a difference with the spacer. It sounds louder now and past 4k you can really feel it working. I'm not expecting too much hp wise yet until the ecu adjusts. i tried to reset the ecu again today but it didnt seem to work
Old Mar 11, 2009 | 05:47 PM
s31t8n8's Avatar
s31t8n8
anyone know what the purpose of the coolant bypass is? i didnt bother installing it
Old Mar 11, 2009 | 08:51 PM
finalforce's Avatar
finalforce
What year is your Z?
Old Mar 11, 2009 | 09:02 PM
s31t8n8's Avatar
s31t8n8
liqalu04
Jan 2, 2022 12:58 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
TDPrank
Sep 29, 2015 12:51 PM
TDPrank
Sep 28, 2015 06:29 AM
