Transmission fluid help!!
Old Aug 14, 2009 | 08:57 AM
cmytaillights's Avatar
cmytaillights
Default Transmission fluid help!!
So last night I decided to change the fluid in my transmission. I have the manual transmission and everything I read said that the z uses 2.99 L or 3 1/8 quarts, so I got 3 L of Motul 300. Everything with the swap went well except that I emptied all three bottles of fluid and it never spilled back out. From what I read you were supposed to fill the tranny untill the fluid started to spill back out the fill hole. I had the car as level as possible so I don't think that was the problem, but I'm kind of at a loss at this point. I'd get another bottle of Motul but I have to have it shipped and it will take 3 days for it to get to me...not in time to dive my car for the weekend. Should I wait to drive untill I get the other bottle, or will the 3 L i put in be enough??
Old Aug 14, 2009 | 09:01 AM
GMZ's Avatar
GMZ
Reach in there and check with your finger, it might be just on the threshold. And keep in mind that when warmed up the fluid will expand somewhat.
Old Aug 14, 2009 | 10:32 AM
350ZthatsMe's Avatar
350ZthatsMe
look for some local...
Old Aug 14, 2009 | 11:03 AM
cmytaillights
Ok I'll try that, thanks for the info!!
Old Aug 14, 2009 | 01:24 PM
Zazz93's Avatar
Zazz93
Default This is from the manual...
The manual tranny requires 3-1/8 qts so I'm guessing you drained all of the fluid and your still a hair shy of 3 1/8 qts. The service manual states you should stick your finger in and feel the fluid just below the fill hole as suggested previously.
Old Aug 14, 2009 | 01:30 PM
06g35meister's Avatar
06g35meister
Off topic question:
Why is the auto like 8 quarts and the manual only 3??? They both seem to be about the same size... is this common?
Old Aug 14, 2009 | 01:41 PM
mclovin.too's Avatar
mclovin.too
Originally Posted by 06g35meister
Off topic question:
Yes, most autos hold tons of that nasty fluid
Old Aug 14, 2009 | 02:04 PM
TheFarmer's Avatar
TheFarmer
Off topic question:
The torque converter itself (depending on size) holds a couple quarts as well. My F-250 diesel transmission takes 14-15 qts
Old Aug 14, 2009 | 05:05 PM
DivinDriver's Avatar
DivinDriver
Torque converter, plus the auto has a cooling loop that goes forward to the radiator.
Since it operates hydraulically, rather than straight mechanical like the manual, it needs thinner pressurized fluid to work, and a lot of it, and it has to circulate it for cooling.
The fluid in the manual is simply for lubrication.
lapham3
Oct 7, 2022 03:15 PM
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
