OEM clutch/aftermarket flywheel
Old Nov 14, 2009 | 10:17 PM
ke0ki2k's Avatar
ke0ki2k
Default OEM clutch/aftermarket flywheel
I havent been on in a while, just logged on to see if I could run an aftermarket flywheel with an OEM 350Z clutch? I can get all the parts for a clutch replacement for like 260 bucks, but I cant find a cheap OEM flywheel so the cheapest options are lightweight aftermarket flywheels...but would they mate up and work well with an OEM clutch disk?
Old Nov 15, 2009 | 03:18 AM
SargeZ350's Avatar
SargeZ350
No problem. I´m running an oem clutch with jwt flywheel.
Old Nov 15, 2009 | 05:03 AM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
This place is pretty cheap if you wanted to stay with OEM.
http://www.clutchcityonline.com/nissan_350z.htm
Old Nov 15, 2009 | 08:18 AM
ke0ki2k's Avatar
ke0ki2k
thx guys. secondly how do I know if I even need to replace the flywheel?
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
FYI, in case you need one
http://z1auto.com/prodmore.asp?model...ne&prodid=4109
we stock tons of them
and yes, you can use most aftermarket flywheels - only one I am not sure about is JWT. The ACT, for example, works perfectly, done that combo many times.
Old Nov 15, 2009 | 10:06 AM
THe flywheel will wear similar to a brake rotor. If it is gouged or shows a deep wear pattern, replace it.
Old Nov 15, 2009 | 10:11 AM
johnwigs's Avatar
johnwigs
the OEM flywheel is a dual-mass flywheel and weighs about 35lbs light weight flywheel definantly frees up a S ton of throttle response, kills it when lugging around a parking lot though... easy to get used to... and speed shifting into 3rd is going to be much easier
Old Nov 15, 2009 | 03:16 PM
Z1 Performance
Former Sponsor
stock = 29.9 lbs
350z82
Oct 1, 2015 06:25 PM
