Automatic Transmission (A5) Pan Drain Plug Size?
Old 02-25-2010, 01:54 PM
charlievet
charlievet's Avatar
Smile Automatic Transmission (A5) Pan Drain Plug Size?
Does anyone know the millimeter size and thread pitch of the A5 ATF drain plug? I'd like to install a magnetic plug after I clean the pan. Thanks! Charlie '05 Redline Touring Roadster
Old 02-26-2010, 04:33 AM
rcdash
rcdash's Avatar
As I recall I use a 14 mm socket to get it on and off, but I don't think you will benefit from replacing it with a magnetic bolt. There should be two large magnets at the center of the pan already installed.
Old 02-26-2010, 04:35 AM
JasonZ-YA
JasonZ-YA's Avatar
Manual transmission is M18x1.5
Maybe they are the same for an auto????
Isn't the drain plug a 10mm hex key, not a hex head?
-J
Attached Thumbnails Automatic Transmission (A5) Pan Drain Plug Size?-transmission_fluid_change_004.jpg   Automatic Transmission (A5) Pan Drain Plug Size?-transmission_fluid_change_005.jpg
Old 02-26-2010, 10:18 AM
rcdash
rcdash's Avatar
Nope there is big 'ol pan with a hex bolt in it. The 5AT holds 10 qts of fluid!
Old 02-26-2010, 11:22 AM
charlievet
charlievet's Avatar
Wink
Really appreciate your replies...and it is an external hexagon. Don't know what size wrench is required, but that won't be a problem. The problem is not knowing what size millimeter diameter and pitch magnetic drain plug to order, BEFORE I drop the pan. In addition to cleaning the inside of the pan, I will be adding a Magnefine filter and removing the pan magnet(s). That's why I want a magnetic plug, i.e., so I don't have to remove the pan every time I change the ATF. With a magnet in the drain plug, in the Magnefine filter, and by using Red Line 100% synthetic ester ATF, the ATF will remain cleaner, not accumulate much crap in the bottom of the pan, so I won't have to remove the pan again. Thanks!
Old 02-28-2010, 10:55 AM
charlievet
charlievet's Avatar
Smile
I spoke with a Nissan tech earlier today and he thought, but wasn't sure, the 5AT ATF drain plug was the same size as the engine oil drain plug or M12 x 1.25. Can anyone verify or deny they're both M12 x 1.25? Thanks!
Old 03-05-2010, 04:23 PM
charlievet
charlievet's Avatar
Red face
Well, I changed all my fluids (engine, 5AT, PS, Differential) to Red Line products today. The 5AT drain plug is M12 x 1.25 with an M19 external hexagon. However, I was not able to use a magnetic drain plug because the factory plug is short, about 1/2" threaded, and there is no clearance inside the trans for a longer plug. Thanks!
Old 03-05-2010, 04:38 PM
rcdash
rcdash's Avatar
Did you find any debris in the pan? How much material was adherent to the magnets?
burglapfd
12-06-2020 01:04 PM
seagrasser
10-11-2015 03:27 PM
10-04-2015 07:55 PM
Quick Reply: Automatic Transmission (A5) Pan Drain Plug Size?
