Would 87 octane gas through a cel?
Old May 12, 2010 | 06:50 AM
redlinedifterzx's Avatar
redlinedifterzx
Default Would 87 octane gas through a cel?
Generaly I would use premium but in this case today I had to make my last $3 last. I was running on 0dte so filled up half a gallon on 87 instead of 91 when I made it to base and stopped at the gate I noticed my cel had turned on.
So long story short I barely made it to
my destination but my question still is on an empty tank would 87 octane have enough change in detonation and timing to cause my cel to turn on
Old May 12, 2010 | 06:55 AM
Entaille's Avatar
Entaille
damnit man do you know what else you could have done with that three dollars??!
Old May 12, 2010 | 07:00 AM
redlinedifterzx
Umm buy a snickers
Old May 12, 2010 | 07:01 AM
onagao's Avatar
onagao
You do realize why you need the higher octane gas for the Z, right?
Old May 12, 2010 | 07:06 AM
redlinedifterzx
Of course but without my debit or credit card on me and 3 dollars in cash I had to make choice at the risk of either being stranded on the freeway or barely getting were I needed to be. I just need a yes or no because I won't be able to get a code reader until sat
Old May 12, 2010 | 07:11 AM
plumpzz's Avatar
plumpzz
Did you close ur gas tank? 87 wont cause a CEL. The computer will jus pull timing.
Old May 12, 2010 | 07:15 AM
DemitriHKS's Avatar
DemitriHKS
Thats a lot on the dollar menu...
Old May 12, 2010 | 07:44 AM
qqqqball's Avatar
qqqqball
2 more dollars and you could have gotten a Vietnamese hooker
Old May 12, 2010 | 07:45 AM
redlinedifterzx
Yea I doubled checked when I got here gas caps on
I know it could be anything but first things that come to my mind are gas? Dirty maf or maybe a loose non fouler bc of the test pipes. I know I have a brake light out but I highly doubt that's the issue
Old May 12, 2010 | 07:50 AM
Ronin82's Avatar
Ronin82
2$ bottle night +1$ to spare. Win!!
Old May 12, 2010 | 07:57 AM
F34RL355's Avatar
F34RL355
i had more then 3$ when i was 7 years old
Old May 12, 2010 | 08:01 AM
Nexx's Avatar
Nexx
5 here.
Old May 12, 2010 | 08:06 AM
scotts300's Avatar
scotts300
87 no CEL, loose cap = CEL.
0dte when it first comes on is like 1.5 gallons of gas left. We typically go 50 miles when ours blinks "- - - -".
Old May 12, 2010 | 08:21 AM
redlinedifterzx
My gauge is highly inaccurate iv never filled my tank past 14 gallons
let alone there are times it reads empty and iv only filled it with 6 gallons
so I don't trust it. At im just hoping there isn't a day that it's actually accurate and I get stuck somewhere but I had driven close to thirty miles on before I got my .8 of a gallon so honestly I have no idea what's in my tank at the moment
Old May 12, 2010 | 08:41 AM
mavtais's Avatar
mavtais
OP, hopefully you did not rush to base on 87 octane. Car must pull timing, so higher RPM is bad for engine (knocking).
Redlinedifterzx, calculate your gas mileage at each fill up (reset trip odo) and you should be able to tell when you are really coming close to empty.
Old May 12, 2010 | 08:43 AM
uglyduc's Avatar
uglyduc
My dealer filled up my tank with 87 when I purchased the Z. 87 will not cause a CEL. What other mods do you have? TP/HFC's or headers maybe?
Old May 12, 2010 | 08:51 AM
redlinedifterzx
Oh god no. Iv heard horrible stories from friends who's parents borrowed there car and didn't no it took premium and filled with regular.
I only went with one step below premium and I did my best to keep it under 3.5k
Old May 12, 2010 | 08:52 AM
drivessidewayz's Avatar
drivessidewayz
Sounds like a coincidence to me.
Old May 12, 2010 | 08:57 AM
redlinedifterzx
As of right now I have test pipes hks exhaust 5/16 pleneum ur pulleys ram air intake sways springs grounding kit and
I'm sure you can check off sways and springs on the list of possible causes
the only thing I touch in the last two days was the front bumper to install the amuse cf lip and I refilled my window washer fluid
it just came on today though so I guess untill I get a code reader until them i'm kinda los. On that not dies anybody know if ammco will use a code reader or do they just guess after listening about the symptoms. Iv heard mixed stories
Old May 12, 2010 | 09:04 PM
biohazard53188's Avatar
biohazard53188
You dont need an OBD reader. You can just do the ECU reset via the pedal method and count the number of times the CEL blinks between pauses. It will give you a code.
