Cheap fuel rail adapters?
Old May 18, 2010 | 04:13 PM
spent's Avatar
spent
Default Cheap fuel rail adapters?
Will any of the cheap ebay fuel rail adapters fit on a VQ35DE? I know there is some higher quality adapters that sell for 70$+ but I am trying to keep a tight budget and these ebay fuel adapters seem like a reasonable alternative...
Here's an example...
http://cgi.ebay.com/ebaymotors/FUEL-...mZ260570869889
Anyone see why these wouldn't plug right into the fuel dampers on the rails?
Thanks
Old May 18, 2010 | 04:59 PM
terrasmak's Avatar
What kinds of mods are you doing that you need fuel rail adapters?
Old May 18, 2010 | 05:24 PM
spent's Avatar
spent
The engine is going into a 240sx, meaning a return fuel system...
Old May 18, 2010 | 05:29 PM
blknblk's Avatar
blknblk
http://www.dynotunenitrous.com/store...?idcategory=42
Edit: woops NM, this isnt what your're looking for.
Old May 18, 2010 | 05:57 PM
spent's Avatar
spent
Found this on one of the ebay ads... I won't be able to verify the damper measurements till tomorrow but I will let you all know what I figure out.
Old May 18, 2010 | 06:43 PM
binder's Avatar
binder
the ebay link you have fits perfect.
i used the exact same one for my return fuel system on stock rails until i went with CJM stuff.
you need the oring from the factory damper and you're good to go.
Old May 18, 2010 | 07:13 PM
Italianjoe1's Avatar
Italianjoe1
Can anyone confirm that it's the same size for the HR motor?
Old May 18, 2010 | 07:28 PM
binder's Avatar
binder
should be. vq motors run similar setups. that's why the maxima is listed on that page.
not too many variations in the fuel rail setup for nissans and i'm almost certain all vq engines have the same fuel rail adapters. I took a chance for 10$ and bought one. it happened to work out just fine.
Old May 18, 2010 | 07:31 PM
Italianjoe1
Yeah, from the look of it I'm guessing it's right. I was gonna make something up myself, but for that price, it's not even worth the time i'd spend. Guess i'll grab one and see what happens.
Old May 19, 2010 | 04:06 AM
spent's Avatar
spent
I ordered 2... I will give you guys an update when they come in.
Old May 19, 2010 | 04:11 AM
JasonZ-YA's Avatar
JasonZ-YA
sweet, in for outcome...
-J
Old May 24, 2010 | 05:04 PM
spent's Avatar
spent
Got them in, fit perfect!! Not only is it a AN-6 Fitting by the fitting screws out and there is a 1/8 NPT thread. BTW, it turns out I only need one so if someone needs one, 20$ shipped!! Save a few dollars and don't deal with Ebay..
I will work on pictures, hopefully I will get some for you guys by Wednesday. I don't know if 350z owners know this, but the Nismo Type-A FPR actually bolts right to the fuel rails too... so, if you were to leave you input line intact then remove the dampener on the driver side, all you would have to do is run the return line from the FPR!! Viola!! I don't understand how Z owners didn't know about this all along... I've searched several forums and I've seen no sign of people knowing this... ~200$ and you have a complete return fuel return system!!
Old May 24, 2010 | 06:07 PM
binder's Avatar
binder
it's actually 1/4" npt on the back of that fitting.
and not so fast on teh 200$ return fuel. You still need the expensive 6an line, then you need a return correction kit along with the hardware to run from the top of the fuel pump basket to the return correction.
basically that FPR that mounts on the lines is replacing the 140$ aeromotive one we have. And if you decide to upgrade your rails down the road aftermarket rails won't allow that style FPR to make on them.
so great for a stock system i guess but you still have more things to order to get a full return system.
Old May 25, 2010 | 04:11 AM
spent's Avatar
spent
What I am doing is pulling out the AN fitting and putting a 90deg npt to nipple elbow, just running stock style rubber hose. AN fittings look nice, but way to pricey. Do you know what the stock fuel line size is?
Uriyo_
Sep 8, 2021 08:46 AM
