5W-30 to 5W-40 will cause higher oil pressure
Old Jul 16, 2010 | 12:30 PM
codek's Avatar
codek
Default 5W-30 to 5W-40 will cause higher oil pressure
Will going from 5W-30 to 5W-40 will cause higher oil pressure?
I have a stock 2007 350z about 50k miles. The car is stock.
I'm looking at the Eneos 5w-40 but was wondering if it would be a good choice considering my car is stock
Old Jul 16, 2010 | 01:01 PM
Why would motor oil alter oil pressure? You could fill the motor with olive oil and pressure would remain the same.
Old Jul 16, 2010 | 01:10 PM
Blu_Blur's Avatar
Blu_Blur
I notice difference in oil pressure between my old 5w-30 and my current 0w-40 when the oil is around 3k miles, at operating temperature and under load.
Old Jul 16, 2010 | 01:12 PM
plumpzz's Avatar
plumpzz
hydraulic pressure depends on pipe geometry and fluid parameters. ofcourse viscocity will affect pressure.
Old Jul 16, 2010 | 01:23 PM
Nexx's Avatar
Nexx
+1, along with the lubablity, and proscrastinistic variables of the flux capacitors.
Old Jul 16, 2010 | 01:39 PM
midz350's Avatar
midz350
Old Jul 16, 2010 | 02:03 PM
nathanwl2004's Avatar
nathanwl2004
I believe there is a word for just this sort of ocassion.... oh yes..............OWNED..
Old Jul 16, 2010 | 03:05 PM
NismoZ_840's Avatar
NismoZ_840
Yes, but only at higher temperatures. Both act the same (5w) when at ambient temperatures and as they heat up the oil starts to thin. The 40W thins slower than the 30w. Since the oil system volume is fixed, it takes more pressure to pump a more viscous (thicker) fluid thus your oil pressure should be a little higher for the 40w.
Here's a diagram that may help...
This is from the best post ever on oil and well worth a read by any car owner...
https://my350z.com/forum/engine-and-...-and-info.html
If that still doesn't answer your oil question, try here:
http://www.bobistheoilguy.com/
A good general rule about oil pressure is NO or very low pressure is VERY bad and of most concern. You have either a leak or the oil is so thin it's losing effectiveness. This will kill the motor. Too high a pressure is a concern too because your stressing the oil system and seals, thus the reason you don't go redlining the car right after startup, you need to let the oil and engine warm up to keep the pressure at a reasonable level and things to expand/contract as the Nissan engineers intended. You're not likely to kill the motor right away with too high pressure (except if you had a massive system/seal blow out right away), but you increase the risk of leaks and failures leading to no oil pressure and killing the engine down the road.
LMAO on the Lube poster
Old Jul 16, 2010 | 09:51 PM
winchman's Avatar
winchman
It depends on the temperature you're talking about. For a cold start at 0 degrees F, both would yield about the same pressure. For a cold start at moderate temperatures and at normal operating temperature, the 5W40 would be higher.
For a cold start using 5W30, I see 120 psi on the coldest days, and over 100psi on the hottest (100 degrees F)days. I doubt that cold start pressure with 5W40 on a hot day would be higher than with 5W30 on a cold day.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
