Dream Workes Heads?
I was hunting for more info on the new DW supercharger and I found this:
http://www.dreamworkes.com/350zz.ivnu
"The New 350Z Starts with some good power. Not enough for you Fast Drivers?
Let us show you how to blow away the competition!!!
Custom Dream Workes Heads -
Ported and High Polished on all intake and exhaust ports lets your new head flow a higher fuel/air mixture; combined with new
Dream Workes Camshafts and you achieved some huge power gains."
Can some of the My350z vendors try to dig up some info on the new head and camshafts? Is this just a ported and polished stock head or a new unit?
Thanks!
Jeff
Thanks!
Jeff
Here's an email reply from Dream Workes regarding the heads:
"Our heads are factory heads that are ported 40,000s of an inch and polished. They are still under testing. Price has not yet been set. The heads should be available in 60 days.
Thanks,
DREAM WORKES RACING "
Thanks,
Performance Nissan
Performance Nissan
Thanks,
Thanks,
Originally posted by FairladyZ
I want to know about this heads and cam thing, too. It seems alittle fishy to me. They are working on heads/cam and blower at the same time?
http://www.dreamworkes.com/about.ivnu
I think you will find they are making more than just a SC for the Z. Dream workes is preparing to offer a complete line of perfomance modifications for the 350Z.
As the web page says "With special attention to super car performance for both the New 350Z and Sentra SER Spec V
Dream Workes has developed performance parts available to the enthusiast that will enhance performance in areas of engine, drive train, suspension and braking.
Available parts include; performance heads, cams, computers, headers, cat back exhaust, clutches, ring/pinion gears, adjustable coil over shocks, lowering springs, strut braces, sway bars, carbon fiber front splitters, rear wing, high performance calipers, larger rotors and brake pads".
Originally posted by teh215
I do not care about how much material or how smooth the polish is. I need to see CFM before and after in intake and exhaust ports. .0040" seems like to little material removed to make any difference.
I know it does not seem like much, but I am sure there is some improvement.... Now, is it worth the money ($1500?), hmmm.
I just bought a pair ( retail ) from Nissan for $1200. & then had them port & polished for "mo" money! If I had known that the above were deliverable, $1500 would have been a good price.
Originally posted by jran76
That is .04" I believe.
Originally posted by ravaz
I'm betting that you have to send them your own as a core, or maybe they are charging 1500 to port and polish your own and sned you them back? Dunno..
I'm curious about whether this is a core swap too. It would seem that the heads would be somewhat susceptible to abuse. Might get stripped spark plug threads, heat damage, etc.
Sounds like it will be a good bit more than $1200 if there is no core swap.
I emailed asking if there was a core swap. If they respond, I'll post their answer.
Jeff
I believe jran was guessing on the $1500 price, as according to DW the price hasn't been set yet.
I emailed asking if there was a core swap. If they respond, I'll post they're answer.
Jeff
Jeff
.04 is 4 one-hundreths, .004 is four one-thousanths and .0040 is forty-thousanths of an inch.
I also agree with Jesse though, the amount in not significant, it is where and how more than the amount removed that will effect flow.
Originally posted by zland
How much of a gain will this mod provide? Estimate the best you can if you dont have dyno's.
One last thing, I guy in Houston ported and polished a Altima VQ35 head and stated that he gained 30 HP (there abouts I will double check the exact amount).
Edit, here is the thread....https://my350z.com/forum/showthread....ltima+and+port
