where the hell can i get a slave cylinder for a 2007 350z!!!
Old Aug 4, 2010 | 06:39 PM
b.dunn24's Avatar
b.dunn24
Default where the hell can i get a slave cylinder for a 2007 350z!!!
i noticed the recall and nissian WILL not replace it for me and it is in that window (20,000 to 36,000miles) sooo i did it myself i dropped the tranny took out the slave cylinder but can not find the part anywhere not even at a nissian dealer its like they never even heard of it!! it would be awesome if someone could give me a site or a shop i can go pick one up at i need my car back!!! thanks
Old Aug 5, 2010 | 12:17 AM
terrasmak's Avatar
Look under throw out bearing
Old Aug 5, 2010 | 01:41 AM
350ZTheStandard's Avatar
350ZTheStandard
is this what your talking about???
http://www.courtesyparts.com/350z-pa...5_778_780.html
or:
http://www.courtesyparts.com/350z-pa...5_778_781.html
scroll down under part # 30620
you could always search courtesynissan.com for anything NISSAn
Old Aug 5, 2010 | 01:55 AM
Z04's Avatar
Z04
if you went to mathews nissan i find that hard to believe. always got my work done there and if it was a legit TSB/recall and you are under warranty, they will fix it.
plus if i read that recall thread correctly, that is for the clutch master cylinder. if you disassembled your transmission to get to this part(from service manual):
CSC (CONCENTRIC SLAVE CYLINDER) PFP:30500
Removal and Installation NCS0029M
CAUTION:
If transmission assembly is removed from the vehicle, always replace CSC (Concentric Slave Cylinder)
body and CSC tube. Return CSC body insert to original position to remove transmission
assembly. Dust on clutch disc sliding parts may damage seal of CSC body and may cause clutch
fluid leakage.
Do not disassemble CSC body.'
that is not what the recall is for.
Old Aug 8, 2010 | 05:29 PM
b.dunn24's Avatar
b.dunn24
that is where i went and they straight up told me there was no recall for the slave cylinder and they could not even find a slave cylinder in there computer, all they had was the ext. slave cylinder which bolts to the side of the tranny and uses a small piston and pin(which you prolly already knew) buttt its all good i did it myself. i found the part at nissianconnection.com.......that is not what i was looking for thats the master cylinder not the slave. the master cylinder was not the problem when i took the slave cylinder out it looked like it was replaced before and the seal was place in wrong. if the master cylinder was bad usually there would be fluid on the floor board.
Old Aug 8, 2010 | 06:15 PM
DavesZ#3's Avatar
DavesZ#3
Of course there is a recall for the 07 slave cylinder. The question is - does your car qualify as it's not on ALL 07 cars.
https://my350z.com/forum/vq35hr/3281...-cylinder.html
Check that thread to see if you VIN # is one fo the ones that's included.
Old Aug 12, 2010 | 07:57 AM
b.dunn24's Avatar
b.dunn24
I did check the vin it was good that's y I didn't understand what they were saying but as i said I did it my at and its back to running like new
Old Jul 30, 2020 | 05:56 PM
Fadi33z's Avatar
Fadi33z
So, where did you get the part from?
Old Jul 30, 2020 | 07:32 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Master or CSC available anywhere, dealer, online.
However, if you are replacing CSC, don’t bother with OE CSC, it will die again. Go with the Z Speed Performance HD CSC or eliminate the internal with replace with an external conversion, the Z Speed CMAK (clutch movement alteration kit). Think Z1 offers similar external conversion as well.
Old Jul 30, 2020 | 07:38 PM
Fadi33z's Avatar
Fadi33z
Apreciate you! Dealers asking ridiculus price for stuff that do not work.
I will get the one you told me about!
Old Aug 1, 2020 | 07:02 AM
HRMoneyPit's Avatar
HRMoneyPit
Ten year bump
Old Aug 3, 2020 | 05:43 PM
Zelduh's Avatar
Zelduh
Originally Posted by HRMoneyPit
Ten year bump
True, as evidenced by the improper use of the currently woke vernacular of the "operating cylinder".
JjL
East Canada
Jun 12, 2019 03:04 AM
kyin
Sep 29, 2015 06:57 AM
Ace2347
Sep 22, 2015 03:12 AM
hardkicks
Sep 20, 2015 12:28 PM
