Z33Art V3.0-LS1/TH400 Swap
Old Apr 5, 2011 | 06:18 PM
  #181
Nebiros's Avatar
Nebiros
Sorry guess I phrased that wrong... I wasn't sure if the placement was in that position so that you would be able to use the factory shift cable or if you had to modify the linkage at the transmission where the cable mounts up.
Were you able to use the factory shift cable or did you go with an aftermarket kit?
As far as the weight distribution, do you have any 4 corner weight comparisons?
Old Apr 5, 2011 | 07:06 PM
  #182
Quamen's Avatar
Quamen
I'm using a B&M pro ratchet shifter.
Old Apr 6, 2011 | 03:41 AM
  #183
Quamen's Avatar
Quamen
On a side note I will be starting a new thread soon with V3.1 .
Getting a cage put in sometime in early May. Plus twin fuel pumps, fuel cell and solid bushings. Most of which is already done.
Old Apr 11, 2011 | 04:31 AM
  #184
Quamen's Avatar
Quamen
Just some pictures from over the last month or two. Have a bunch more updates but I am waiting until they are completely finished to post them.
Welded in solid subframe bushings
My new gauge and switch panel where the radio was. Air/Fuel gauge and vacuum/boost gauge. The switches are main power relay, data log, nitrous and wideband calibration. Each switch will have an indicator LED by it also which aren't shown in the picture. There will also be an error code indicator between the gauges. Still have to space the panel out correctly so it sits flush, but you get the concept.
Old May 12, 2011 | 06:04 PM
  #185
Quamen's Avatar
Quamen
The 570z goes in for the cage tomorrow! Still removing more wiring to save weight on the front end. Getting a new torque converter that can handle nitrous. The new larger Howe radiator shows up tomorrow also!
Old May 13, 2011 | 10:34 AM
  #186
bbs350z's Avatar
bbs350z
^ were you running into coolant issues with the old howe??
Old May 19, 2011 | 09:01 AM
  #187
Quamen's Avatar
Quamen
My old Howe radiator had a couple of coolant passages that had slowly become crimped from the zip ties for mounting fans. Decided I wanted a slightly bigger radiator also since I run an underdrive pulley and my water pump is going slower.
Old May 19, 2011 | 09:03 AM
  #188
Quamen's Avatar
Quamen
Pictures of the cage that Clocks Off Racing is putting in the Z! Just going with a 10.0 cage for now. Planning for a Ford 8.8 solid axle and adjustable four link suspension this upcoming winter.
Old May 19, 2011 | 09:42 AM
  #189
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
How come you're keeping the stock rear strut bar?
Old May 19, 2011 | 03:05 PM
  #190
Quamen's Avatar
Quamen
Just didn't see a reason to cut it out at this point.
Old May 19, 2011 | 10:18 PM
  #191
bbs350z's Avatar
bbs350z
no room for the groceries i see
Old May 21, 2011 | 04:04 AM
  #192
Quamen's Avatar
Quamen
Lol. I actually have a ton of room in the Z now that the speaker enclosure is gone.
Old May 21, 2011 | 05:03 AM
  #193
Cass007's Avatar
Cass007
Lookin good
Old May 22, 2011 | 04:47 AM
  #194
Quamen's Avatar
Quamen
So I finally moved into my new house this week and the Z got delivered! Sitting in her new home with the new larger Howe radiator and and Clocks Off Racing tubular radiator mount.
Pictures of the finished cage also.
Old May 30, 2011 | 06:33 AM
  #195
Quamen's Avatar
Quamen
Well the cage and interior has the first coat of paint on in it. Going to finish painting today! It sure is red but there wasn't much else I could do.
Old May 30, 2011 | 05:15 PM
  #196
Cass007's Avatar
Cass007
Nice!!
The new garage is awesome btw, love the high ceilings!!
Old May 30, 2011 | 05:37 PM
  #197
Quamen's Avatar
Quamen
Originally Posted by Cass007
Nice!!
The garage is awesome! I am still working on finishing the cabinets I made but everything else is good to go in the garage. Still have to buy some shelving and finish putting stuff away from the move though so it is kind of a mess right now.
Old May 31, 2011 | 09:51 AM
  #198
bbs350z's Avatar
bbs350z
damn that garage is sweet! got room for another lol
Old May 31, 2011 | 10:53 AM
  #199
Quamen's Avatar
Quamen
Lol. I do as in the winter the car is going sideways. However, Ryan (eltness350z) is getting first dibs.
Old May 31, 2011 | 11:05 AM
  #200
03threefiftyz's Avatar
03threefiftyz
Garage shipped to 21702......
