350Z Coolers
Old Dec 3, 2003 | 09:25 PM
MySunset350Z's Avatar
MySunset350Z
Default 350Z Coolers
350Z Coolers
i think im getting close to pushing my car to the limit without having to worry about things blowing up.
i will be upping all my engine mods next summer, and so im gonna have to baby the engine and other parts of the car a bit to keep her happy. im looking around for all different types of coolers for the 350z.
to be more exact,
Engine Oil Cooler
Transmission Cooler
Rear Differential Cooler
i've heard that B&M is pretty good with engine oil cooler and transmission cooler, but i'd like some more input from other club members on that before i get anything.
also has anyone bought any sort of rear differential cooler for their 350z?
Old Dec 3, 2003 | 09:29 PM
mr2fasterthanyo's Avatar
mr2fasterthanyo
i heard nismo is coming out with a tranny cooler.
you can always make your own though. you can get many different size coolers online. they make them for tractors and all their parts, so there is a wide variet available
Old Dec 3, 2003 | 09:30 PM
jesseenglish's Avatar
jesseenglish
I'm gonna be building a custom oil cooler for my car using a lot of B&M parts once I get some time. They make some pretty efficient coolers to fit in smaller areas, and I'm gonna need that to fit one up front next to my intercooler.
Old Dec 3, 2003 | 09:37 PM
MySunset350Z
B&M makes oil cooler kits for imports, but im not sure on the size specs which is why im asking around.
im sure your probably a hell of a lot more limited on space then i am with your intercooler.
but the B&M kits seem pretty small and easy to instal.
Old Dec 4, 2003 | 06:11 AM
MY350Z.COM's Avatar
NISMO coolers are ridiculously expensive, and they don't work any better than the cheaper brands. Just paying for the name if you go with NISMO.
Old Dec 4, 2003 | 06:35 AM
MySunset350Z
agree
Old Dec 4, 2003 | 06:40 PM
azrael's Avatar
azrael
since we're relatively close to each other, we should work together to come up with a custom solution. I haven't decided whether or not to attempt a dry sump yet, but I know I want an oil cooler for sure. The Nismo parts are unbelievably expensive ($1250 for the oil cooler), and not any better that what we could come up with for a lot less money. I also have to design around an intercooler, as I intend to install twin turbos in the next year or two.
Old Dec 4, 2003 | 08:03 PM
2003z's Avatar
2003z
I run 275s all around at the track, and boiled my power steering fluid time b4 last, so I got the nismo power steering cooler, and it works good
Old Dec 4, 2003 | 08:16 PM
MY350Z.COM's Avatar
a comparable cooler of that small a size can be had for cheaper than $150 that nismo sets.
Old Dec 4, 2003 | 08:52 PM
MySunset350Z
im not worrying too much about the steering fluid. i go in a straight line ne way.
b&m makes an oil cooler for 200 tops
and a trans cooler for 100 tops
but i have yet to see anyone who has them....this is getting annoying. i might have to be the dummy on this one and find out the hard way. buy and try.
still looking for a rear diff cooler. i know mine gets really really hot at the track.
Old Dec 5, 2003 | 05:25 AM
2003z's Avatar
2003z
yes, but I had a $150 coupon from nissan corporate to use any on parts and accessories, and the cooler was actually only 128 at my dealership.
Old Dec 5, 2003 | 05:45 AM
MY350Z.COM's Avatar
that's great. how'd you get the coupon?
Old Dec 5, 2003 | 06:50 AM
dchi_t's Avatar
dchi_t
for the oil cooler setups, are they all installed via sandwhich plate between block and oil filter? and the sandwhich plate has a thermostat which allows temp opening so the oil wont be under normal operatin temp. if so, it sounds extremely easy enuff to make, besides u can get air craft oil coolers for fairly cheap.
Old Dec 5, 2003 | 07:11 AM
azrael's Avatar
azrael
I believe this is the way it is usually done, although in our case, I think we need to remotely mount the oil filter, because the space in that area might be cramped if we add a sandwich plate. I'm changing my oil (yet again) this afternoon, so I'll have a better memory of the exact space available in that area.
it really is an easy thing to make.. you just need a 'radiator' for the cooling, the sandwich plate with thermostat, and some stainless steel connecting lines w/ fittings.
Old Dec 7, 2003 | 07:42 PM
jesseenglish
Actually, I just moved this weekend to Arizona.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
