350 EVO 3.917 Final Drive?
Old Dec 8, 2003 | 11:50 AM
lafdclass002's Avatar
lafdclass002
Default 350 EVO 3.917 Final Drive?
Has any one had this mod done yet? Thumbs up or down on this?
Old Dec 8, 2003 | 12:01 PM
zillinois's Avatar
zillinois
It's not available yet. They can be ordered from 350evo.com.
We haven't heard much about them for a couple of weeks.
Old Dec 8, 2003 | 01:20 PM
dwnshift's Avatar
dwnshift
We have had many people sign up for the pre order special. We are taking $100 deposits on our web site to reserve a set. We are setting the expected arrival date for 3/04. They are in production now.
I give it a thumbs up! but I am a little biased.
Old Dec 8, 2003 | 01:54 PM
Bait-Fish's Avatar
Bait-Fish
I haven't the time at the moment to check the other thread on this so I'll post my Q here. Obviously the speedometer will indicate higher than actual after this mod so a recalibration will be required, no? Is this easy enough to do?
Old Dec 8, 2003 | 02:08 PM
peptidbond's Avatar
peptidbond
I am not sure if the speedo will see any difference. All this mod does is require the driveshaft to spin 3.917 times for every one rotation of the wheel axel. Since the speedo reads at the wheel and not the drive shaft, it should not matter. Please correct me if I am wrong though.
Old Dec 8, 2003 | 02:34 PM
FLY BY Z's Avatar
FLY BY Z
Well, dwnshift said that speed is measured at the wheel as opposed to the drivetrain so a recal should not be needed. I disagree. The wheels will be turning faster at any given speed with the gears installed and will also show a higher speed than normal on the speedo and also will calculate on the odometer faster. The wheels are, in reality, the final pieces of your drivetrain so it is still being measured on the drievetrain. I don't know how to measure speed NOT from the drivetrain unless you use GPS. I could be wrong but calculating at the wheel does not seem to be any different.
Old Dec 8, 2003 | 02:41 PM
peter's Avatar
peter
80mph = 80 mph (example), unless the wheels are smaller or bigger the speedo will show the correct speed. How can wheels turn faster at the same speed with different gearing??
The speed is measured at the wheels and therefore there will be no differents on the speedo.
Old Dec 8, 2003 | 02:48 PM
dwnshift's Avatar
dwnshift
You do not or will not need anything re calibrated. Speeds are taken from the wheel speed/ ABS sensors on the car. We have been running this mod in my street car for while now.
Changing tire size will effect the wheel speeds and if you get the ratio out of whack between the front and rear it will reall mess with the VDC. There is someone on this forum that is exp this now.
THIS MODIFICATION WILL NOT MESS WITH YOUR SPEEDO!
zillinois's Avatar
zillinois
The rpms will be higher at any given speed. The speedo will not the effected by the gearing. I assume the rpm of the wheel is measured by a sensor. The rpm number is translated into miles per hour based on the distance of the sensor from the hub, then sent to the speedo.
Old Dec 8, 2003 | 02:50 PM
zillinois's Avatar
zillinois
Dwnshift, did you see my clarification of the other post regarding 60mph?
Old Dec 8, 2003 | 02:59 PM
zzzya's Avatar
zzzya
You may want to rethink this as the tires, if not changed in diameter, will only spin so many rotations for a certain speed regardless of the gearing. If the speedo was coming from the tranny, then there would be an issue because with this mod the engine rpms, tranny and drive shaft will all be spinning faster to make the car go the same speed as with the stock final drive. This is the benefit for some people because you in essence keep the car at a higher rpm at lower speeds giving you more of the engines power and torque, but you also decrease the top speed of each gear. Since the wheels are the last step and that is where the computer is getting the speed, all final drive and tranny mods will not effect the speedo readings. However, if you change wheel diameter then you will effect the speedo.
Old Dec 8, 2003 | 03:04 PM
dwnshift's Avatar
dwnshift
BINGO!
Old Dec 8, 2003 | 03:39 PM
Bait-Fish's Avatar
Bait-Fish
Thanks for the clarifications. Didn't mean to stir anything up there, dwnshift That's pretty slick measuring at the wheel vs ye olde tyme pinions.
Old Dec 8, 2003 | 04:20 PM
FLY BY Z's Avatar
FLY BY Z
Yep now that I think about that, I was wrong. I am not sure what I was thinking. It's good that the Z is measured from the wheel. Dwnshft sorry for the misinfo. The only drawback is the motor spinning higher but it won't be a whole lot higher. However, you may have to hit fifth in the 1/4 which would be a lot of shifting unless Technosquare has raised your limiter but this should be a nice mod for many people as the isn't really a drag car.
Old Dec 8, 2003 | 04:25 PM
dwnshift's Avatar
dwnshift
No worries.........I am just glad to be here!
Old Dec 9, 2003 | 10:03 AM
Blownaway's Avatar
Blownaway
damn March, that is way out of my time table my Nismo dif has been under my desk for about three weeks already, waiting to be installed. I really cant postpone the big install of everything until March....Anyway for me to get a set faster than that, other wise I might have to skip it....
Old Dec 9, 2003 | 11:09 AM
Jim Jones's Avatar
Jim Jones
Default March 2004???
EVO -
Why is it taking so long? 2 weeks ago, you said 4 weeks, which would have been before X-mas. Why the delay. I agree with the guy posting above. That messes up my timetable. I wanted all the N/A mods in with a couple of months to run on them before maybe going F/I. I guess the 3.9 won't be part of my set-up until way later.
Old Dec 9, 2003 | 11:24 AM
dwnshift's Avatar
dwnshift
I can get you a one off right away for about $3500......but I thought maybe you would rather wait and save a bunch.
Mass production takes time.....they have to get all the tooling ready and they have other projects they are completing. I am trying to get things moving as fast as possible. I hopefully will be able to get them shiped as they are finished so that will speed it up by a few weeks for the first orders that we took.
Cheers
350EVO
Old Dec 9, 2003 | 02:33 PM
Blownaway's Avatar
Blownaway
From an installation standpoint, once the diff is installed, how much time do you think it is to pull it and install the the gear?
Old Dec 9, 2003 | 03:25 PM
dwnshift's Avatar
dwnshift
I would say the difference would be an hour from what it is to replace the diff.
Obadabot
Jun 18, 2023 11:31 PM
Jambo016
Sep 16, 2016 01:08 PM
