Custom Engine Grounding/Earthing Kit
Old Dec 7, 2002 | 05:02 PM
  #61
all_bark's Avatar
all_bark
dont waste your time, just send insaneamine $75.00!
it is worth it, I promise!
Old Dec 7, 2002 | 08:52 PM
  #62
ares's Avatar
ares
Veteran
another option which I may choose is to just go to a local auto shop. they have done work for me in the past, charge me 60$ an hour. bring in the pre stripped and measured wire and ends, let them crimp it, and should be able to get out of there with 5 or 10$ charge.
also checked, I actually paid 3.95 per pair for the ends. the total so far is about 55$. including the screws and washers that totalled like a buck or 2 from lowes.
my reasons for not ordering was not even for the 20$ savings, but strictly for the fact that I like to do things myself if at all possible. I mod mostly for the option to just work on the car. gains are not even important.
Old Dec 8, 2002 | 05:42 PM
  #63
Barrett350's Avatar
Barrett350
Default insaneamine
What is your contact information? I would like to purchse a set of cables from you? Have you done a yellow set? If so please post some pics. Thanks....
Barrett
Houston, TX
Old Dec 8, 2002 | 06:11 PM
  #64
topeewala's Avatar
topeewala
WHEN CAN I GET MINE!!
insane maine we must speak!
i dont think u have one dissatisifed customer... keep up the good work, ur probably bankin on us...
Old Dec 8, 2002 | 06:17 PM
  #65
fdao's Avatar
fdao
Default Re: insaneamine
Barrett
Houston, TX
Barrett,
Click on his Profile. You can email him for the kit. Very well done kit, BTW.
Old Dec 8, 2002 | 09:36 PM
  #66
Intrepid's Avatar
Intrepid
I ordered a silver set from insaneamine. Will post when I receive it.
Old Dec 8, 2002 | 10:45 PM
  #67
Shoots's Avatar
Shoots
all_bark
You are correct!
True craftsmanship, and a great guy to work with!
-Shoots
Old Dec 9, 2002 | 02:43 PM
  #68
zPilott's Avatar
zPilott
Got the kit in the mai today, Hopefully I will find the time to install it tomorrow. It looks great, evry bit as nice as the pics suggest. Thanks a lot for the quick turnaround and the quality craftsmanship!!!
Old Dec 9, 2002 | 04:51 PM
  #69
insaneamine's Avatar
insaneamine
Inventor
Z-Xtreme.com
Thumbs up Hello Mellow Yellow!
Alright… well, maybe not so mellow… but definitely yellow!
Attached Thumbnails Custom Engine Grounding/Earthing Kit-dscf0001.jpg
Old Dec 10, 2002 | 07:26 PM
  #70
unho's Avatar
unho
has anyone done a before and after dyno? I would be very interested to see the graph.
Old Dec 11, 2002 | 11:09 AM
  #71
350Now's Avatar
350Now
Default E-mail
Insaneamine,
Hope you get my e-mail. Silver please
Old Dec 11, 2002 | 05:13 PM
  #72
insaneamine
Inventor
Z-Xtreme.com
Default Finally
Bloooooo!
Attached Thumbnails Custom Engine Grounding/Earthing Kit-blue_roll.jpg
Old Dec 11, 2002 | 05:14 PM
  #73
insaneamine
Inventor
Z-Xtreme.com
Default More Bloooo
Blues Set.
Attached Thumbnails Custom Engine Grounding/Earthing Kit-blueset1.jpg
Old Dec 11, 2002 | 05:15 PM
  #74
insaneamine
Inventor
Z-Xtreme.com
Default Samples
A few samples of the colors.
Attached Thumbnails Custom Engine Grounding/Earthing Kit-samples_1.jpg
Old Dec 11, 2002 | 05:19 PM
  #75
Sabre's Avatar
Sabre
That looks like it might be close the the DB color. Do you think they are a close match in person?
Old Dec 11, 2002 | 05:39 PM
  #76
insaneamine
Inventor
Z-Xtreme.com
Default Blue color
Actually, these wires are a tad bit darker than the "Daytona." The wires are more of a royal or sapphire blue.
Darker, yet still very attractive.
I should be getting a roll of the lighter "Daytona" blue this weekend. I'll post more when I have a set made.
I purchased just enough of this darker blue to make one set. I wanted to see how it looked since I wasn't 100% sure.
Old Dec 13, 2002 | 04:55 AM
  #77
insaneamine
Inventor
Z-Xtreme.com
Default FYI
The following was lifted from another web site dedicated to automotive grounding systems. I hold no responsibility for its accuracy. I am posting for FIY purposes only!
On a normal system, electric current flows from a positive terminal to a negative terminal through the car body. But there are much resistance at connectors of body, engine and transmission. The resistance disturbs this flow of electricity to a degree that electrical components such as computer, lamp and spark plugs cannot perform at their peaks. In order to get the highest performance out of any automobile, it is necessary to achieve a maximum electricity flow with the least resistance along its electrical circuit. In short, a grounding system does to your electrical circuit like a high performance intake & exhaust system does for the gas. We believe such system is the basic of all tune-up if you want to unleash the maximum performance of your car.
While making sure that the operational circumstance is the same, the below table indicates a 7.7% of total resistance which originates from the car body & the same 7.7% of battery voltage which is being wasted due to the absence of a grounding system.
Attached Thumbnails Custom Engine Grounding/Earthing Kit-voltage.jpg
Old Dec 13, 2002 | 04:57 AM
  #78
insaneamine
Inventor
Z-Xtreme.com
Default continued...
What does the Grounding System do?
The Grounding System can achieve an extreme improvement on electricity flow and stability by providing a direct ground path from the body, chassis and engine components to the battery negative.
This theory has been known & such system has been used in the racing world for years. Since 1.5 years ago, it has become the hottest modification performed by car enthusiasts in Japan. Its effect on automobile has been proven by dyno tests again and again.
Old Dec 13, 2002 | 04:59 AM
  #79
insaneamine
Inventor
Z-Xtreme.com
Benefits:
- Faster engine start-up - You can feel the difference even with A/C on and at maximum fan speed. This system reduces the loss of electricity to nearly zero at ignition coil and produces better ignition spark.
- Stable idling - You will hear your car engine noise quieter than before.
- Throttle response - System installed. They indicate a higher torque & horsepower gain. Car used for this dyno test was a Lancer Evolution VI. A max. horsepower gain of 5hp and up has been achieved on a Honda Integra TypeR.
Attached Thumbnails Custom Engine Grounding/Earthing Kit-graph.jpg
Old Dec 13, 2002 | 05:01 AM
  #80
insaneamine
Inventor
Z-Xtreme.com
More benefits:
- Increase low & middle engine torque - It helps to achieve a close-to-perfect combustion at low or high revolution of engine, resulting in faster acceleration. A max. torque gain of 0.5kg-m and up has been achieved on a Subaru Legacy BH5.
Attached Thumbnails Custom Engine Grounding/Earthing Kit-maxpower.jpg
