Optima Lightweight Battery Installation
Old Jan 12, 2004 | 11:08 AM
Brad4rdHay's Avatar
Brad4rdHay
Default Optima Lightweight Battery Installation
What hardware is needed. Do I need to make a mount cause the batery looks alot smaller.
Old Jan 12, 2004 | 11:32 AM
350zdanny's Avatar
350zdanny
My friend did the optima yellow top install on his 240sx recently and we did not have to modify the battery tie down at all. The optima was much lighter and thinner, but the height was close enough. I will measure the height of my battery and the height of his optima when he gets home from work and let you know if it will work on the Z.
Dan
Old Jan 12, 2004 | 12:15 PM
mofoz's Avatar
mofoz
how many lbs does this battery actually save?
Old Jan 12, 2004 | 12:21 PM
Brad4rdHay's Avatar
Brad4rdHay
About 22lbs.
Old Jan 12, 2004 | 12:30 PM
toykilla's Avatar
toykilla
wow.. is this battery strong enough to run an audio system>?
Old Jan 12, 2004 | 12:34 PM
Brad4rdHay's Avatar
Brad4rdHay
I hope so.
Serisouly, should it work fine with my stock radio?
Old Jan 12, 2004 | 01:04 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
There actutally stonger than stock.
Old Jan 12, 2004 | 01:11 PM
westpak's Avatar
westpak
SFZCC
Plus unless you have the car off you should be running off the alternator so the main battery's concern is cranking amps and life.
Old Jan 12, 2004 | 01:14 PM
350zdanny's Avatar
350zdanny
Should have no problem with a normal aftermarket system. Once you start getting crazy you might have problems, but that's true of any battery.
Old Jan 12, 2004 | 03:53 PM
trackstar's Avatar
trackstar
At some point, I plan on putting an Odyssey battery in. 15 lbs for $85? What is the stock battery, 45 lbs? Can't hurt to lighten up the front end
http://www.odysseyfactory.com/default.htm
I had one in my M3, never had a problem starting the car, no matter how cold,plus I left an interior light on for a week while I was out of town, quick jump and the battery was good as new.
I actually bought it here:
http://www.batterymart.com/battery.mv?p=ODY-PC680
Here is a good write up on SLA batteries:
http://www.stealth316.com/2-dynabatt.htm
Old Jan 15, 2004 | 06:03 PM
taujbwar3's Avatar
taujbwar3
Default optima
optima yellowtop is one of the best batteries for stereos period
Old Jan 16, 2004 | 11:06 AM
GY-Z's Avatar
GY-Z
is a light weight battery universal?(in other word can the battery fits in any car?)
Old Jan 16, 2004 | 11:30 AM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
I have this Optima Lightweight Battery in my car:
http://www.performancenissanparts.co...roducts_id=194
I had to adjust the back side of the bracket to get it tight enough, but it works well....
Old Jan 16, 2004 | 07:10 PM
trackstar's Avatar
trackstar
Usually you need to modify the brackets. Some drop right in, it depends on the battery and the car.
Old Jan 16, 2004 | 08:35 PM
GY-Z's Avatar
GY-Z
Default trackstar
thanx for the help..
so anyone know which light weight battery will fits right into our z33?
Old Jan 16, 2004 | 09:49 PM
DaveO's Avatar
DaveO
Default Re: trackstar
The yellow top 51R (reverse poles) is the one I'm considering.
Jeff, is that the one you put in your car?
DaveO
Old Jan 17, 2004 | 07:51 AM
jmark's Avatar
jmark
I believe Jeff sells them.
Old Jan 17, 2004 | 01:15 PM
zand02max's Avatar
zand02max
I have the Optima Yellow Top in my Z. It does not just drop in. I had to get my wires extended so the battery would fit correctly.
This battery is awesome for running high end stereo systems.
Old Jan 17, 2004 | 02:30 PM
Jeff@Performance
Performance Nissan
Wow, your poles are reversed. For the 350Z, you need the SC51RDA and you won't have to mess with the cables as they will go right on. Here's a pic of my car...
Old Jan 17, 2004 | 10:12 PM
alphared's Avatar
alphared
You tap your amp lead to the stock fused block? I thought you couldn't do that?
