JWT clutch question
Old Feb 2, 2013 | 06:00 PM
Haptic's Avatar
Haptic
Question JWT clutch question
I'm looking into getting a JWT clutch and flywheel due to its popularity and quality, and on the conceptz website you have the option to choose between an 03 or an 04-06. The thing is i have an 03 Z but i recently swapped the transmission to a CD-009 due to synchro grinding. I'm unsure which clutch kit i should get. Can a knowledgeable person shed some light on this for me? Thanks in advance.
Haptic's Avatar
Haptic
Website: http://www.conceptzperformance.com/C...&Car_Type=350Z
Old Feb 2, 2013 | 06:29 PM
harman850t5's Avatar
harman850t5
You'll use 04-06. The 03 trans has a longer pivot ball than the others.
Old Feb 2, 2013 | 11:21 PM
bealljk's Avatar
bealljk
I've had a great experience with JWT…either way you're covered...
Old Feb 3, 2013 | 04:59 AM
XChacalX's Avatar
XChacalX
by the JWT website , they have 3 different flywheel for the 350z ..
you should get the one that will fit your year
each of those 3 flywheel has a different encoder wheel
FYI read this ; http://www.jimwolftechnology.com/wol...GEN-2-ONLY.pdf
by not getting the right one. your engine wont be working properly.
so I suggest you to stick to an 03 flywheel if your 350z is an 03
Old Feb 3, 2013 | 05:20 PM
Haptic's Avatar
Haptic
Can anybody else chime in? Got two conflicting answers here.
Old Feb 3, 2013 | 05:28 PM
SilverStone2003's Avatar
SilverStone2003
03 engine... There for you would need a 03 flywheel.
Old Feb 3, 2013 | 06:55 PM
Haptic's Avatar
Haptic
03 flywheel and 06 clutch then?
Old Feb 4, 2013 | 09:52 PM
RENFRO's Avatar
RENFRO
Solid question. I'm planning to swap my 03's CD008 to a CD009 and do the JWT Clutch/Flywheel combo at the same time. Hopefully I can figure out what parts are needed...
Old Feb 5, 2013 | 03:45 AM
XChacalX's Avatar
XChacalX
come on
I gave the answer , and a reference directly from JWT
what else do you need ?
Old Feb 5, 2013 | 06:19 AM
meanz's Avatar
meanz
03-06 are the same, 07 is when it changes. I ordered mine from IPP.com. Its listed from 03-06 when you order it. I have an 03 with the cd09 trans. http://www.importpartspro.com/jwthdclco03n.html
Old Feb 5, 2013 | 07:13 AM
Haptic's Avatar
Haptic
Originally Posted by XChacalX
come on
No. With all due respect you told me i need an 03 flywheel. That'd be all well and good if somebody else hadn't told me it doesn't matter. Also you mentioned nothing about the clutch.
Old Feb 5, 2013 | 07:15 AM
Haptic's Avatar
Haptic
I'm going to contact JWT after work today and ask them personally. I appreciate the help however.
Old Feb 5, 2013 | 01:19 PM
harman850t5
Does the kit include a stainless line and new pivot ball? To my knowledge the pivot ball is the reason they need to know the year. But with a cd009 you'll already have the newer clutch fork and pivot ball. So you'll go 04-06.
I thought the three flywheels were vq35de rwd, vq35de fwd, and vq35hr
Old Feb 7, 2013 | 04:40 PM
XChacalX's Avatar
XChacalX
any news from that call ?
07ZEKE
Aug 23, 2021 09:15 PM
issyz
Jul 2, 2017 03:04 PM
