New engine build. Need some help.
Old Jul 18, 2013 | 10:54 PM
AM1144's Avatar
AM1144
Default New engine build. Need some help.
Just recently had a rebuild of my motor. Wiseco forged pistons .020 overbore, k1 forged connecting rods, motor was balanced and blueprinted, arp L19 head bolts, Jim Wolfe block cooling mod, HR oil pump, water pump, and thermostat. Existing mods are a greddy twin turbo setup, fuel lab fuel system, full exhaust, and an OS Giken triple plate clutch.
My question is, the shop said I need to get an oil change within a few hundred miles because metal shavings and such could get in the motor. They said I can't just shock the motor and put full synthetic oil in. What do I do in this situation. And no, I can't call the shop that built it
Old Jul 18, 2013 | 11:35 PM
jerryd87's Avatar
jerryd87
why cant you call the shop? the reason they say that is the rings will never seat, if you did a soft break in i would wait till after 1k miles for synthetic.
Old Jul 19, 2013 | 12:01 AM
AM1144's Avatar
AM1144
So what type of oil would work best for this initial oil change?
Old Jul 19, 2013 | 12:11 AM
jerryd87's Avatar
jerryd87
i used basic no brand oil with comp cams additive for my first 2 oil changes at 20 and 50 miles then rotella 15w40 since, tryed 15w30 but saw higher oil temps
Old Jul 19, 2013 | 01:01 AM
AM1144's Avatar
AM1144
Awesome. Thanks for the help. I'm at about 200 miles since the rebuild so I'm planning on doing the change this weekend
Old Jul 19, 2013 | 06:30 AM
SCRoadster's Avatar
SCRoadster
I used Motul organic break-in oil.
Old Jul 19, 2013 | 06:23 PM
AM1144's Avatar
AM1144
Thanks!
Old Jul 19, 2013 | 08:27 PM
bealljk's Avatar
bealljk
Sounds like you got your answer - but +1 to a basic, no name oil. You sorta want a little more friction between the new components to wear on each other a little bit more than normal. If you want to go nuts they do sell 'break-in' oil that would suit your needs.
Old Jul 20, 2013 | 05:15 AM
AM1144's Avatar
AM1144
What weight would be best for these motors?
Old Jul 20, 2013 | 06:53 AM
pyshin's Avatar
pyshin
This may shed some light on your question:
https://my350z.com/forum/vq35hr/3003...-analysis.html
liqalu04
Jan 2, 2022 12:58 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
