Vdc off and SLIP light on and limp mode
Old Jan 30, 2014 | 02:52 AM
lukypetr's Avatar
lukypetr
Default Vdc off and SLIP light on and limp mode
Hi everyone, I'm new to the forum. I just purchased a 2003 350z 6 speed. I purchased this car with the current problem and have searched the threads but I still have not come up with a solution.. VDC OFF and SLIP lights are on and it will not rev past 2k rpm. I ran the codes and get P2135, P0550, P0222, and P0123. I have done the ecu reset and relearning procedures but the cel light stays off for a couple of seconds then comes back on. The vdc and slip light never go off and they come on immediately when I start the car. I have also tried unplugging the battery for 24hrs and still no luck. I figured that it might be either the throttle body or the position sensor on the pedal, Any ideas how to narrow my choices? Any help would be appreciated. Thanks in advance.
Old Jan 30, 2014 | 03:01 AM
travlee's Avatar
travlee
Master
so you bought the car with these issues? how much did you pay for it? you should do all the relearns.
http://www.technosquareinc.com/350reset.htm
p2135 = throttle position sensor
p0550 = power steering pressure sensor
p0222 = Throttle Position Sensor
p0123 = TP Sensor
Old Jan 30, 2014 | 03:09 AM
lukypetr's Avatar
lukypetr
I got it for less than $5000. I did all the relearn procedures a bunch of times but still the same problem. I will say that when I got the car the throttle body was making a loud whining noise and after the resets it went away but the other problems were still there.
Old Jan 30, 2014 | 03:15 AM
travlee's Avatar
travlee
Master
try replacing the throttle body, i have a feeling you might spend some coin to fix the car
Old Jan 30, 2014 | 03:19 AM
lukypetr's Avatar
lukypetr
Any way to know for certain if its the throttle body or the position sensor on the pedal? Or is it hit or miss?
Old Jan 30, 2014 | 03:23 AM
travlee's Avatar
travlee
Master
well you have 2 codes on it and you said it was making a noise..... good place to start
Old Jan 30, 2014 | 03:39 AM
lukypetr's Avatar
lukypetr
Good Point
Old Jan 30, 2014 | 03:57 AM
travlee's Avatar
travlee
Master
my friend used to have one.. let me see if he still does
Old Jan 30, 2014 | 04:34 AM
lukypetr's Avatar
lukypetr
ok thanks
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
