Modified Revup Oil pump!!
Old Feb 11, 2017 | 05:42 AM
  #81
Total D's Avatar
Total D
For HR and VHR, the DE/revup are right behind it.
And it finally begins!!!!
Old Feb 21, 2017 | 07:46 AM
  #82
Total D's Avatar
Total D
Default Release!!!
Finally, ready for release.
Gear Details:
* Drop in
* Hardness of gears is twice that of stock gears, and not brittle like other gears on the market
* RPM Range: 8500RPMS (With supporting internals of course), same gears running 8600rpm at 6bar of pressure in a road race build currently.
* Billet Heat Treated Hardened 17-4 Stainless Steel
* Moly Ceramic Dry Film Lubricant Coating
* Tolerances within .0005" of the original gear.
Back Plate Details:
* Bolt on
* 7075 Aluminum
* Eliminates the flex
* Brand Logo, for authenticity
Oil Pump Details (Optional)
* Helps Eliminate cavitation during higher rpms.
* Better flow with ~10% increase
* Larger Volume of flow throughout the rpms, stock held around 5" of vacuum, whereas after modifications,the pump held 20" of vacuum.
Old Mar 10, 2017 | 07:18 PM
  #83
gills's Avatar
gills
Where does one go about buying the revup/de pump? And is there a price that can be shared?
i sent you a PM a few days ago. Very interested in purchasing.
Old Mar 13, 2017 | 07:46 AM
  #84
Total D's Avatar
Total D
You can look up Suckerpunch Motorsports on Google or FB. I don't want to get in trouble for posting sale threads for not actually being a vendor. Just like showing everyone what's available.
Old May 24, 2017 | 11:45 PM
  #85
rottingcat's Avatar
rottingcat
thought cost was just going to be rev up pump +$395 as you mentioned initially? it's $900 (and out of stock) according to your website
Old May 25, 2017 | 10:38 AM
  #86
Total D's Avatar
Total D
The $395 was added to the pump, it was the work being done to the the pump with revup gears, similar to what Cosworth was. Then we decided to do billet gears, that's when the the price went to $899. We are in the middle of production of our 3rd run, so we can definitely get you taken care of. So, price of pump, pump work, coatings, and gears is what you're getting for $899.
Old Aug 20, 2017 | 08:57 AM
  #87
Total D's Avatar
Total D
There's 6 DE/Revup and 4 HR/VHR pumps available, if anyone is looking to upgrade their oiling system. Feel free to contact Sucker Punch, EPS, Concept Z, MA-motorsports, and Real Street for pricing.
Old Aug 21, 2017 | 02:52 AM
  #88
wizard's Avatar
wizard
Hi, just found this thread now.
Assuming everything on a car was stock (mine isn't) - could you run this oil pump on a DE motor without harming anything else? This has been tested up to 8,500rpm?
Or if not, what supporting internals would one need to rev the motor to 8.5
Old Aug 21, 2017 | 05:23 AM
  #89
Total D's Avatar
Total D
Sure, adding the oil pump to any motor ( stock or modded) will be beneficial. Stock motors have broke the OEM gears, so adding this pump/gear setup, will give you better insurance.
Yes, it has been tested to 8600rpms actually, in a road race motor. For the avg person, I would say rods, pistons, valvetrain, cams, oil pan spacer, and oil cooler. RPMs kill rods, so if the stock rods can't handle that kind of abuse, don't bring it that far up. On a stock setup, we have seen 7800-8k, but I always recommend adding the supporting mods for safety.
Old Aug 22, 2017 | 02:36 AM
  #90
wizard's Avatar
wizard
Thanks - can you be a bit more specific about whats needed for supporting mods?
What internals do you think work well with your oil pump if we put a conservative rpm limit at say, 8k?
Old Aug 22, 2017 | 06:40 AM
  #91
Total D's Avatar
Total D
Welcome, if I were spinning it to 8k+, I would do oil pan spacer, oil cooler, Cams (Tomei, Kelford, JWT), valve springs and retainers (from same companies), EPS oil galley gaskets, ARP L19, and at very least eagle rods and weisco pistons. The stock rod bolts can handle it for a little while, but eventually they are gonna go. So, I would just build it right the first time and be done.
Old Dec 22, 2017 | 07:42 PM
  #92
Ahmad A Ahmad's Avatar
Ahmad A Ahmad
Default Vq35de oil pump gear
Regarding Vq35de oil pump gear only... I need only the gear... How much it coast?
Old Dec 22, 2017 | 09:51 PM
  #93
Total D's Avatar
Total D
PM sent Ahmad!
Old Dec 2, 2020 | 10:13 AM
  #94
pascal's Avatar
pascal
Default Vq35de oil pump gear(s)
PM me the price of gears for the VQ35DE oil pump if still available...
Thks
Old Dec 2, 2020 | 10:33 AM
  #95
bealljk's Avatar
bealljk
Thks
Jeramiah is more active on his Instagram than here. Maybe check out his website too (google suckerpunch motorsports) But he is a great guy and does great work. If you end up buying a pump from him let us know what you think.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
