Sourcing a new engine
Old Apr 3, 2014 | 03:06 PM
robsilver350's Avatar
robsilver350
Default Sourcing a new engine
I've been looking at LKQ as the place to get a new engine for my 2003 MT. Going through their inventory, there are different engine dates (e.g. thru 09/2003, thru 10/2004, from 11/2004), but does anyone know if it matters as long as it's before 10/2004 since I assume from 11/2004 is the uprev DE engine?
Also, can a previously AT engine be used in my MT?
Old Apr 4, 2014 | 03:47 AM
Conway_160's Avatar
Conway_160
Well I have an 04 G35 6MT that has a new'ish motor from a AT 03 350Z. As long as you don't get a revup motor you'll be fine.
Old Apr 4, 2014 | 04:33 AM
myfirstzcar's Avatar
myfirstzcar
Check the build date of the car to be sure, it's on the driver's door.
Old Apr 4, 2014 | 06:32 AM
rich2342's Avatar
rich2342
What's the price range for one of these going? Mine is burning oil. Nice to know for future reference
Old Apr 4, 2014 | 06:53 AM
Conway_160's Avatar
Conway_160
I think the one I got cost them like $800.
Old Apr 13, 2014 | 09:16 AM
robsilver350
From what I've found so far the used DE engines (and you have to be careful because some are just the core, some are long block, and some are full assembly) range from 1000 to 2000 depending on miles.
Ask if they have compression test results and walk if they don't. Even though they will say that they have a warranty on parts, they will not reimburse for labor. So let's say you buy a motor with no comp test for 1500, have someone with heavy lifiting equipment swap it for 1000, and upon install find it has a busted cylinder; you'll end up getting your 1500 back on the motor, but you're out the 1000 on labor to your mechanic.
Old Apr 23, 2014 | 02:51 PM
robsilver350
Can anyone tell if this is a nonrev engine?
https://www.iaai.com/Vehicles/Vehicl...adRecent=True#
Old Apr 23, 2014 | 03:47 PM
dcains's Avatar
dcains
The RevUp motor came only in the '05 6MT Anniversary and the '06 6MT (any trim).
Old Apr 23, 2014 | 04:05 PM
dizenman's Avatar
dizenman
Thats from an auto so it is a DE
Old Apr 23, 2014 | 06:19 PM
robsilver350
Thanks! "New" engine found and on its way
lapham3
Oct 7, 2022 03:15 PM
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
