350z gutless after mods..
Old Apr 7, 2014 | 05:22 AM
1slowxj's Avatar
1slowxj
Default 350z gutless after mods..
so i took my car out for first time of year yesterday over the winter i installed test pipes and motordyne isothermal plenum spacer, other mods are jwt popcharger hypertech programmer and hr y pipe previously installed.. car sounds awesome but has no *** whats so ever drove it all day no change.. ended up losing to a bolt on charger and wrx both of which i beat last year (unchanged) with no real competition so something is screwed up.. any ideas??https://my350z.com/forum/images/smilies/suicide.gif
thanks!
Old Apr 7, 2014 | 05:40 AM
terrasmak's Avatar
When you lost, what were your times, what times did you run last year?
Old Apr 7, 2014 | 05:44 AM
92K1500's Avatar
92K1500
Did you retune after the intake/exhaust parts were installed?
Are you still running the old, sat all winter fuel?
Old Apr 7, 2014 | 06:21 AM
1slowxj's Avatar
1slowxj
havent ran in 1/4 yet just playing on back roads, i just put some gas in it yesteray afternoon ran it down as close to empty as i could no i just did the tps reset they give you with spacer, should i just unhook negitive and try that or uninstall and reinstall program?
Old Apr 7, 2014 | 08:25 AM
JCITY's Avatar
JCITY
You really need a tune.Meaning,full dyno tune.
Got to be running lean for starters.
Old Apr 7, 2014 | 08:57 AM
1slowxj's Avatar
1slowxj
think it would be worth getting osiris mail in tune? closest place is in p.a that would do anything with it watkins glen is this coming weekend would like to do something before then just cant believe it would lean out that much to really lose power it a completely different car getting tire put on today then gonna try unhooking battery then uninstall program and see what that does
1slowxj's Avatar
1slowxj
still no cel though if it was that lean would think it would throw code
Old Apr 7, 2014 | 09:35 AM
Junkster's Avatar
Junkster
Probably need a tune for sure,
But as for the endless amounts of variables, doing some canyon runs i dont think really can point to you having "lost power"....
Old Apr 7, 2014 | 09:53 AM
travlee's Avatar
travlee
Master
mine never threw a code when lean, and a mail in tune is not optimal... it will work though
Old Apr 7, 2014 | 09:59 AM
92K1500's Avatar
92K1500
At least with uprev you can get the software to check everything about your car. If the tune doesn't fix it you might be able to find out what's causing it.
Have you checked for vacuum leaks around the spacer?
Old Apr 7, 2014 | 11:46 AM
bmccann101's Avatar
bmccann101
its most likely not a mechanical issue.. and yes, a canned tune will help enormously.
Old Apr 7, 2014 | 11:59 AM
1slowxj's Avatar
1slowxj
ill go check now
Old Apr 7, 2014 | 12:07 PM
1slowxj's Avatar
1slowxj
noticed with key on engine off had a very high pitched whine did tps reset and it went away im thinking that may have been the issue damm rain needs to go away to know for sure
Old Apr 7, 2014 | 12:31 PM
92K1500's Avatar
92K1500
Do you have a roadster with a broken/missing top?
Are your wipers broken?
Old Apr 7, 2014 | 12:57 PM
myfirstzcar's Avatar
myfirstzcar
A CAI by itself will cost you power, it needs a tune.
Old Apr 7, 2014 | 02:08 PM
1slowxj's Avatar
1slowxj
pretty sure problem was solved with reset just went for a few laps around the block seems to pull hard again wouldnt even set you back before sure as hell hope so lol any input on innovative tuning out of buffalo ny?
Old Apr 7, 2014 | 03:11 PM
myfirstzcar
I think I've seen them online before. Do they offer uprev? Try 'em out and report back to me LOL.
Old Apr 7, 2014 | 03:14 PM
travlee's Avatar
travlee
Master
wonder if you can get one from uprev directly and they charge for your core until it is returned to them.....
Old Apr 7, 2014 | 05:33 PM
1slowxj's Avatar
1slowxj
haha gotta decide whether to do can tune or give them a shot i guess..its runnning much better now but still something id like to do soon
Old Apr 7, 2014 | 05:35 PM
1slowxj's Avatar
1slowxj
uprev has them listed as dealer/installer
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
