What is RPM ar idle?
Old Feb 2, 2004 | 10:41 AM
iLLestJrz's Avatar
iLLestJrz
Default What is RPM ar idle?
I just noticed this morning that my idle was about 490 rpm. I think that is too low. I had just installed RT cats and Y Pipe. So I'm thinking I need like a TS ECU to correct this. Any one know if thats right?
Old Feb 2, 2004 | 10:47 AM
infidsg35's Avatar
infidsg35
You might want to boost it. When I installed my Flywheel it did the same thing. But all I did since im friends with the service manager at my dealership is ask him to use The CONSULT II to bump my RMPS up to about 800. It was cheap, fast, and it works.
Old Feb 2, 2004 | 10:52 AM
iLLestJrz's Avatar
iLLestJrz
So go and ask for an adjustment using the "consoultent II"? What does that exactly do?
Old Feb 2, 2004 | 11:05 AM
etx's Avatar
etx
The CONSULT II unit will flash program data to the ECU. Check out http://www.nissan-techinfo.com/nissan/ecm.asp?
My datalogger says about 650 at idle and my Z is dead stock.
Old Feb 2, 2004 | 11:14 AM
azrael's Avatar
azrael
the idle depends on cooland and intake air temperature. unless it's stumbling, I don't think 490 RPM is an issue. Furthermore, exhaust system changes would not affect your idle.
Old Feb 2, 2004 | 12:04 PM
EL Diablo's Avatar
EL Diablo
Default Re: What is RPM ar idle?
I run about the same RPM's at idle
if your done modding then I would get a reflash to finish up your car,
Knowing you, your not done yet. hehe
Old Feb 2, 2004 | 12:08 PM
350zdanny's Avatar
350zdanny
The factory service manual says 650 is normal with a swing of 50 revolutions in either direction.
Try an idle relearn. If that doesn't work find a mod friendly dealer and they will bump the idle for you.
dan
Old Feb 2, 2004 | 12:14 PM
infidsg35's Avatar
infidsg35
Yes, The CONSULT II its called I wasnt realy sure but all I know is it works. They will plug it into your cars ECU port and from the Consult II they can see your RMPS and higher them and lower them. Also when you think your happy with the RMPs turn on your A/C to make sure its not to high. The whole process will take about 2 minutes and it is a setting that will stay even if you reset your ECU. Hope this helps
Old Feb 2, 2004 | 12:23 PM
infidsg35's Avatar
infidsg35
Thats 650 is about right. I bumped mine up to 800 cause when the RPMS drop below that my Lightweight Flywheel would make that loud cement mixer sound but as soon as the RMPS hit 800 the sound was like cut in half till 2K then it disapears.. So since you have the Flywheel which is why your RPMS droped you might want to try it also... Plus it makes it move drivable as in easier to get out of 1st. When your RMPS are at 450 you let out the clutch a lilililililil bit to much you can stall real easy. Its up to you..
Old Feb 2, 2004 | 12:44 PM
ares's Avatar
ares
Veteran
was it cold? mine idles at 1300 when I start it up, then falls to 800 or so.
490 seems a bit low...
Old Feb 2, 2004 | 01:27 PM
iLLestJrz's Avatar
iLLestJrz
Yeah I think its too low, I'll raise the RPM's when I get a chance. I was driving for about 30 mins, waiting at a stop light when I discorved this. Will it be harmful if I leave it like that for too long?
Old Feb 4, 2004 | 05:44 PM
1320350z's Avatar
1320350z
if you did the rt cats your A/F might be to lean
Old Feb 5, 2004 | 01:45 PM
greddy4777's Avatar
greddy4777
ok...just caught this thread...
i have test pipes, nismo exhaust and headers...my car idles at 490 too...just below 500...
does this mean this is hurting my engine...?
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
pslamp32
Feb 8, 2017 09:07 AM
Justin100
Nov 29, 2015 03:58 PM
