need help/opinions
Old Nov 18, 2014 | 05:19 PM
l2frankie's Avatar
l2frankie
Default need help/opinions
2006 rev up 350z with header back bolt ons
while attempting to change my crank pulley my mechanic said i was having oil leak from the crank. he noticed the actual crankshaft is cracked and my only 2 options would be either replace the motor or crack open the motor and replace it. which would be a cheaper bet
if cracking open the motor is cheaper ill probably end up doing cams
Old Nov 18, 2014 | 06:07 PM
terrasmak's Avatar
Post a pic of the cracked crank shaft
Old Nov 18, 2014 | 07:31 PM
l2frankie's Avatar
l2frankie
id have to see if he took a picture of it anyways sorta scared about opening the motor and finding more problems. the car run good cant even tell the it has a problem.
Old Nov 19, 2014 | 12:59 PM
cashmoney03's Avatar
cashmoney03
I'd be curious to see how he could tell it was cracked in two spots without pulling it. Then again, I've seen motors with split cranks run as if nothing was ever wrong so who knows.
Old Nov 19, 2014 | 02:10 PM
l2frankie's Avatar
l2frankie
talked to him earlier today. he has no actual pictures of the crank. from what i understood on the phone ( bad audio on phone ) he pulled the bolt to the harmonic off and oil starting pouring out. after he cleaned it up he looked on the inside without pulling the pulley and noticed the cranks cracked.
Old Nov 19, 2014 | 03:01 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Even with a crank that's cracked, oil will NOT be "pouring out". Now, it could have damaged the rear main seal, which would cause a massive leak. You need to go see what is happening before doing anything else. If it's as bad as your wrench claims, you'll need to rebuild or replace the VQ.
Old Nov 19, 2014 | 07:36 PM
l2frankie's Avatar
l2frankie
Just picked up my car. He had pictures and a video of the crack. Oil was not pouring but a small puddle did leak out. He suggest a new engine in case anything else is wrong intetnally. Hate to best a dead horse but hr motor boots to de headers?
Old Nov 19, 2014 | 07:41 PM
l2frankie's Avatar
l2frankie
I take back my last post finding put the de to motor swap cost to much
joonvang
Feb 18, 2015 08:31 PM
Tanman1986
Mar 30, 2011 05:26 AM
StreetOC192
Jul 18, 2007 09:04 AM
gsazabi
Sep 6, 2005 11:21 AM
