06' 350Z timing chain (VQDE)
Old Mar 28, 2016 | 11:50 PM
Bilazaurus's Avatar
Bilazaurus
Default 06' 350Z timing chain (VQDE)
Hi,
I have about 69000 miles (112000km) on my 06' 350Z. I was wondering, what is the time interval to change timing chain? I cannot find a sure, 100% confirmed info. It costs a lot but if that's what I have to do, then I'll do it, although I wish I didn't have to. I don't think I hear any chain noise.
Old Mar 29, 2016 | 08:26 AM
sportbiketed's Avatar
sportbiketed
According to All Data:
Old Mar 29, 2016 | 08:59 AM
Bilazaurus's Avatar
Bilazaurus
Thanks. But that translates to "replace if needed" which tells nothing. If I paid someone to check my chain I would replace it anyway because opening engine up would cost me way more than a chain.
Old Mar 29, 2016 | 09:11 AM
Spoolin'Fool's Avatar
Spoolin'Fool
the chain will whine when it needs to be changed, the plastic chain guides are what makes all the noise, you shouldnt need to replace it for a while. probably closer to 100,000 miles or so
Old Mar 29, 2016 | 11:01 AM
sportbiketed
You can inspect them yourself by taking off the cover for the water pump.
Old Mar 29, 2016 | 11:09 AM
Bilazaurus's Avatar
Bilazaurus
Isn't timing chain deep in the engine? Is that just a simple cover? Any tutorial?
Old Mar 29, 2016 | 11:22 AM
Bilazaurus's Avatar
Bilazaurus
I already looked up because I was really confused by what you're saying. It's A LOT of work. Mind you, I park my car on the street. I don't have a garage
Old Apr 5, 2016 | 10:49 PM
Justin100's Avatar
Justin100
i would recommend changing your timing chain at 200k miles.
timing chains never really need to be replaced like timing belts. it usually outlasts the car.
i bought a g35 engine and the seller told me it had 105k miles on it.....i took apart the entire engine and built it with forged internals myself. when i was looking at the timing chain i didnt see any real wear on it i replaced it for peace of mind with another used OEM timing chain that i got for like 20 bucks that supposedly came off a 350z with 45k miles on it. I didn't feel the need to buy a new timing chain since its quite pricey.
Old Apr 6, 2016 | 04:03 AM
dkmura's Avatar
dkmura
General & DIY Moderator
The answer to this question is you simply DON'T need to change the timing chain. Period. OP has mentioned none of the symptoms (noise, vibration) which would indicate a new chain would benefit his VQ one bit.
Old Apr 6, 2016 | 04:28 AM
Bilazaurus's Avatar
Bilazaurus
Thank you all very much for making me not spending money on an unnecessary cost.
VxExhaust
Mar 27, 2016 04:15 PM
Sak350
Mar 27, 2016 08:41 AM
