07/08 HR Engine Swap in a 2004
Old Apr 7, 2018 | 02:26 PM
me17z's Avatar
me17z
Default 07/08 HR Engine Swap in a 2004
Hey there. I have an 04 Nissan 350z, and as of right now, I'm needing to engine swap it. I've decided that I want to go with the 07/08 VQ35HR. I've just got some questions regarding putting an HR in a car that was built with/for a DE. My first question is: What is all required/necessary for me to swap an HR into it? And my second question being: Would I need a new transmission? I'm not sure if the "newer" 350z's use the same manual transmission as the older models. These are probably very basic questions, but I don't know so I figured I'd ask. Thanks.
Old Apr 7, 2018 | 03:46 PM
vegasanthony's Avatar
vegasanthony
If I were you I would buy the engine and install it first worry about the electrical later no big deal
Old Apr 7, 2018 | 04:01 PM
travlee's Avatar
travlee
Master
Been done a couple times, you will need way more than you think. Just replace with the same motor
Old Apr 7, 2018 | 04:17 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Here's a recent thread asking about JUST the front clip:
https://my350z.com/forum/2003-2009-n...5-06-09-a.html
Now, the engine.... new front rad support, new harness, new computer, new transmission, new clutch/flywheel/CSC, new hood....
Any more questions?
Old Apr 7, 2018 | 05:12 PM
vegasanthony
word
Old Apr 7, 2018 | 05:17 PM
CK_32's Avatar
CK_32
Don’t you need to get a new hood? Isn’t the HR profile much bigger than the DE?
I’m ganna go with Trav IIRC there is a crap ton of stuff you’re ganna have to do to make the swap happen.
Old Apr 7, 2018 | 06:13 PM
travlee's Avatar
travlee
Master
For some reason i think power steering rack also needs to be swapped
Old Apr 7, 2018 | 08:07 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Not a rumor. The HR starter mounts on the opposite side of the block from a DE. That's why you need the HR steering rack, as well as most of the parts from the front clip.
Old Apr 7, 2018 | 08:28 PM
DarkZ03's Avatar
DarkZ03
another HR swap thread? Why do something that is such a pain for so little gain? I am sure that with all the time and cost involved you could just rebuild your engine and throw some cams in it.
Old Apr 8, 2018 | 04:48 AM
Atreyu'z 350's Avatar
Atreyu'z 350
Old Apr 8, 2018 | 10:33 AM
BluestreamDE's Avatar
BluestreamDE
Cause the HR be bettuh bruh. Guaranteed this guy has these FB 350z group trolls quotes stuck in his head trash talking DEs.
Whatever you decide OP, good luck...
Old Apr 8, 2018 | 08:14 PM
DarkZ03's Avatar
DarkZ03
I wouldn't know because I'm not on FB, but I do hear way too many HR fan boys screaming out there. To which I say MEH, either way you look at it you wont make any substantial amount of power without FI. Either engine will need a proper build at that point unless you want to roll the dice lol.
Old Apr 10, 2018 | 03:23 PM
RENFRO's Avatar
RENFRO
Better off camming your DE. OR, selling the car altogether and buying an HR car.
Old Apr 12, 2018 | 05:51 PM
Frostydc4's Avatar
Frostydc4
^^^what he said!
Old Jun 21, 2022 | 08:25 AM
Riley2001's Avatar
Riley2001
Default Bit late to the party.
I have an auto 2003 350z, the engine blew. Whoopee.
I have a manual 2008 350z available, besides the gearbox, to purchase right now (wrecked, got in an accident but engine bay is completely fine, repairable write off.)
will having an entire donor car besides gearbox make this swap much less of a headache? Could I simply play lego and rip EVERYTHING out of one car and put everything from the HR into my 03? I'd like to keep it auto, it's a street car and heavy traffic where I've. Not looking for smart *** comments, simply need an accurate response if possible as I'm on a small time frame to decide whether or not I buy the car.
Money isn't a massive issue, but is there anything else I'd need if I have the entire car?
cheers in advance.
Old Jun 21, 2022 | 03:04 PM
Timboj's Avatar
Timboj
The advice above still stands. It's not worth the huge amount of effort for such minor gains. Get another DE and throw a few (more?) mods on it.
Having the HR drivetrain is one thing, but you'll have to move over your entire HR harness and ECU, which I assume means several of your 2003 control modules won't work (easily/at all) and all your mounting points (engine, trans, steering rack) are different.
If it was a bare track car and fun project for you then go for it.
Old Jun 21, 2022 | 03:34 PM
DarkZ03's Avatar
DarkZ03
To answer your question directly:
it would make it an easier swap, but your trans isn't compatible so you would NEED to convert to a manual if you want to use that car as a donor.
Old Jun 21, 2022 | 05:32 PM
Riley2001's Avatar
Riley2001
So can't use any sort of adaptor plate?
Brandon Terry
Engine Swaps
Apr 27, 2019 07:12 PM
van46
NA Builds
21
Sep 6, 2012 07:36 AM
mcmanus1806
Jun 25, 2012 10:08 AM
bonnie420
Nov 10, 2009 08:51 AM
