2005 Z: Help requested: Engine knocking at idle
Old Jun 25, 2018 | 08:56 AM
vndr09's Avatar
vndr09
Default 2005 Z: Help requested: Engine knocking at idle ONLY WITH A/C ON
**SEE ATTACHED VIDEO**
Hey guys, I literally just bought this 2005 350Z and once I got it home I noticed it knocking at idle.
It will only do this “knocking” after it’s been driven a while, and only when the A/C fan is on. It can knock as loud as it wants, but as soon as I put the A/C to the off position, it stops. The knocking also stops whenever gas is applied to the vehicle.
I've also noticed the static of the radio at fluctuating volumes. No issues with power steering though.
See the attached video! Looking for any suggestions or anyone that has experienced the same/similar issue! Thanks in advance!
File Type: mov
Last edited by vndr09; Jul 4, 2018 at 09:40 AM. Reason: Problem narrowed down, so post updated!
Old Jun 25, 2018 | 11:41 AM
iideadeyeii's Avatar
iideadeyeii
https://www.virustotal.com/#/file/3d...5a3f/detection
Doesn't sound great, but we need more information. Oil pressure? oil level? It goes away when driving?
Old Jun 25, 2018 | 12:19 PM
K20Z350's Avatar
K20Z350
Based on what you said that it only happens when the clutch is not engaged, I'd suspect it to be part something with the clutch, flywheel, bad install or a combination. If the engine was knocking that loud, I'd imagine you wouldn't be making much power that you would notice it. It also seems to be associated with heat expansion since it only occurs after you've driven it. Or possibly something with the fan or shroud?
I've blown a motor before and it was knocking with or without the clutch being engaged. Oil was coming out of the exhaust port when I took the header off. It drove like crap and was obvious.
Old Jun 25, 2018 | 01:10 PM
vndr09's Avatar
vndr09
Oil pressure and levels are good. It occurs after it’s been driven for a while. Or just driven. In other words, when the engine is warm.
Gotcha, okay, well that makes me feel better. That’s what I was leaning towards too; or at least something non-engine related.
any idea on how I can check those things myself? Or is that something to take to a mechanic?
Old Jun 25, 2018 | 01:19 PM
K20Z350's Avatar
K20Z350
If you are unsure then take it somewhere. I know many wouldn't agree with me but I'd take it to a Nissan dealership. They usually charge 30-100 to diagnose the problem. If not, go to somewhere that specializes in Nissan.
Old Jun 26, 2018 | 05:51 AM
iideadeyeii
I must of overlooked the clutch part. If the clutch pedal is out then TOB. If clutch is pressed then pilot bearing. Could be something else wrong in there, but sounds like engine is fine, but you're going to have to drop the tranny
Old Jun 26, 2018 | 07:59 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Gotta ask the obvious question: what brand and grade of fuel have you been using? Since there was no knocking for the previous owner and on your test drives, something changed and you need to figure out what it was.
Old Jun 26, 2018 | 08:27 PM
vndr09's Avatar
vndr09
The clutch pedal is both in and out. It happens at idle and in neutral. Whether the clutch pedal is depressed or not does not make a difference. Does this make sense?
It happened after I drove the car home from the seller to my garage. Same day I purchased it. But, I did stop on the way home and I put 91 (premium) octane in the car, per the fuel cap instructions.
Like everyone is saying though, since it happens at idle, and only at idle, with the clutch disengaged, it can't really be the engine, can it?
Old Jun 27, 2018 | 04:35 AM
dkmura's Avatar
dkmura
Detonation usually gets worse once more throttle gets added. I'd suggest looking for other causes of that sound.
Old Jul 4, 2018 | 09:11 AM
vndr09's Avatar
vndr09
Updated: first post has been changed.
Knocking only occurs when the A/C is turned on.
Old Jul 5, 2018 | 11:20 PM
mr. sparco's Avatar
mr. sparco
Check AC compressor, associated belt and pulley, clearance as well.
Old Mar 9, 2022 | 10:58 PM
Andrewu24's Avatar
Andrewu24
Default 04 Z 160K Knocking At Idle
My Z Has An Engine Knock Only At Idle, When I’m Stopped And It Progressively Gets Worse When The Engine Gets Warmer. It Sounds Exactly Like Yours. It Started Happening After I Changed Aftermarket Valve Covers To OEM Cuz Aftermarket Was Leaking.
I Don’t Know If This Relates But I Also Have An Oil Leak Somewhere Driver Side Mid Engine. It’s Not The Valve Covers But It’s Somewhere A Little Lower.
This Is Below Under The Valve Cover Next To A Radiator Hose Connecting Into The Engine
I Can’t Upload A Video Of The Sound Atm
Old Mar 9, 2022 | 11:02 PM
Andrewu24's Avatar
Andrewu24
This Is The Only Video Atm
File Type: mov
Old Mar 9, 2022 | 11:15 PM
Andrewu24's Avatar
Andrewu24
[QUOTE=Andrewu24;11074344]This Is The Only Video Atm[/QUOTE
Ace_350z
Jan 5, 2018 01:12 PM
Ace_350z
Jan 5, 2018 10:28 AM
CaychO
Feb 3, 2014 10:23 AM
treefiddyzeeh
Sep 20, 2012 05:48 PM
Crawling_Drunk
Mar 27, 2011 07:54 PM
